donjuan1jr
whats a turbo?
- East of queens west of hamptons
Yea but having that pm3 makes a world a difference.
Wrapping up my fuel setup currently, granted i'm TSI so we're a bit different on the engine side, but I'm running a CM5 & PM3 combo, integrated engineering surge tank, Bosch 044 pump, nylon OEM style quick connect lines, LNF injectors, 1000cc 5th injector, and an AN line conversion up front. I'll report back once i'm fully tuned, but 500ish WHP should be doable with this setup pretty easily.
Would it be possible to keep DI and run more aux injectors (or larger) to meet fuel requirement? Possible set up separate fueling entirely for aux injectors? Meaning separate tank, fuel pump, the whole works?
k04 and stuff.
Thats what I have set up already. Its alot to manage - going to port alone would simplify things greatly
I think you can replace the RS4 or S3 injectors by bigger one, for example the 1000cc or similar and use the USP auxiliary LPFP and controller and that's it.
This supposed to be a simple setup it works like that.
What do you think guys?
Philosophy Of Eagles: Eagles flies only with eagles!
Would it be possible to simplify it and make a separate system? For just aux injection?
k04 and stuff.
