I wanted to get that kit but I didn't want to have to cut into my metal bumper support what did you use to cut it?
Sent from my SPH-D710 using Tapatalk 2
Nope no dyno yet. First time will be the tristate dyno day as long as It's running right. Yes 70mm TB is in the works from you know who.:wink:
I have the same cts kit you do, what are you using for meth? I have the meth pump and nozzles but I have to where to put them? Are you getting some sort of tb plate or putting the nozzles somewhere else?
ahh ok, i guess ill see ya there, off the top of my head didnt remember you were going. Ill probably be rolling there dirty, still out of inspection
assuming hes getting a manifold, im guessing port meth
Thats a stock intake manifold, with a w/m nozzle in each runner.
You could have a bung welded on to your CTS TB pipe for a nozzle or you could drill a hole in a silicone coupler if there is room.
You should use a megasquirt to control the meth and run real injectors if you got the port injection ports
Sent from my HTC Evo 4G Shift using Tapatalk
No need to run meth and port fuel inj, plus theres cheaper ways to run those aux injectors...
