Tmsracing37
Boosty McFlamin Job
- MD
- 06 GTI
I am not going to set here and argue about piston design because both will work fine in the FSI. But having data on how rs4 injectors work at high rpms, higher rail pressure and very short window of time for fuel and air to mix, I believe it’s best to use a piston that can create more turbulence in the cylinder close to and at Top dead center for a better complete burn. The crowns do affect the turbulence in the cylinder and here is a good article explaining why.
http://www.nrhsperformance.com/tech_squish.shtml
Link:Setting Your Squish Clearance
Something we emphasize a lot is the value of getting your squish clearance right. A proper squish clearance makes the motor both more efficient and less prone to detonation. When you're assembling your high performance motor project, this little detail is well worth the small amount of time and effort it takes to get it right. You'll have more power, better fuel mileage, and your motor is less likely to "ping" on you.
In the ideal world, your squish clearance should be set to about .030". Tighter than that risks piston to head contact; looser starts reducing the chamber turbulence effects that you're going for. Unfortunately, I don't think I've ever pulled apart a factory assembled engine that had a squish clearance of less than .050"! So you can see what a huge opportunity this is to improve on your motor.
So let's talk a little about what squish clearance is and how to adjust it. Put simply, a squish band is the area or areas where the piston comes in close proximity to the chamber as it passes through top dead center (TDC). Fuel trapped in this space gets squeezed out at high velocity and generates turbulence in the chamber. Turbulence in the chamber promotes better atomization and less separation of the fuel and air, encouraging it to burn
