keep an eye on those pads
i know someone who burned threw them in 1 event
Will do, thanks for the heads up.
Okay, I was reading the original thread again and it said to skip steps 4-6 if you're only swapping pads out. This means I don't necessarily need the 14mm triple square? Now if I was going to paint the calipers (which I plan on doing), I probably do need them then unless I don't take the calipers off? I also am going to bleed the brakes and use ATE blue.
You only need the 14mm triple square to get the rear carriers off. You only need to take the rear carriers off in order to take off the rear rotors. You can take the front calipers off with the 7mm allen wrench and the rear calipers off with the 13 and 16mm wrenches. If you want to paint the carriers as well as the calipers, you'll need the 14mm triple square for the rear and a 21mm socket for the fronts.
You don't need to take anything off to bleed the brakes or swap fluid. Just a 10mm (I think) socket to loosen the bleeder valves.
Ah. That makes sense. And either way I do it I'm going to need the compressor tool as the new rotors are thicker right? Thanks for the help; not so sure I want to paint the calipers now. Maybe when I need new rotors too.:smile:
If it's just new rotors you may be able to get the caliper and pads back on without it, but it could be a struggle. The piston will pretty much stay in it's last position, but it can be shimmied a little bit. I would have a tool on hand to be safe and save yourself some hassle. It's free from Autozone.
Dan- Thanks, I had a feeling it might have been 11mm
Thanks for the help. BTW, what's your name?
I plan on getting HPS pads and ATE fluid. I'm going to make sure the rotors are within spec though. I'm at 38k with a lot of rev matched downshifting and 1 season of AutoX's. Front rotors are at ~28k because they were warrantied at 10k.
if your putting new pads in you will need the piston caliper tool
Of course my car is still on jacks because I'm going to get the front rotors resurfaced early tomorrow.
unnecessary
