jay745
What Would Glenn Danzig Do
- Slightly Outside Chicago
- Mk6 racecar, Tacoma
So I did some research on this problem Jay, first thing to check is your fuses. There's 2 fuses associated with the steering rack that are somewhat common to go, could be a simple issue. As for the ABS module, highly unlikely the module itself failed since you're not an 09. There's a chance you could get the module reprogrammed at the dealership and fix that issue.
When you come over tomorrow bring your vagcom and let's see what the actual codes are.
Well.... I found the problem while I was swapping wheels with the racecar.... It's supposed to be like this right? guise?
