man with the golden tape.... looks sort of lunar-module-like ... kewl.
:lol: Tom Hanks would be proud. On a serious note though I actually like the Gold. Different, yet functional.
I honestly don't think it's worth the trouble. It will keep the intake cool for a while but when it finally does get warm (and it eventually will) this will just make it stay warm a lot longer by trapping the heat IN.
You graduated with honors in engineering, but clearly failed reading comprehension. I'm not even sure about your engineering skills, but that's a different matter...Really? So our insulation on the pipe and the cooler to the touch feel is just an illusion? I will have to remember that insulation is worthless (since apparently it is only good for keeping the inside warm...not cold, who knew?) when I insulate my house to keep the AC inside in the summer months.
Ever heard of Heat Transfer? Well, I have, and I worked my ass off in college to graduate cum laude at an engineering school, Heat Transfer being one of the classes. So, for example, my wrap. I first have the pipe wrapped in header wrap. This doesn't change the aluminum's thermal conductive properties, but it changes the ambient conditions in which it is surrounded. Therefore, the ambient conditions are cooler for the aluminum which means...who would have thought, the aluminum is not as hot?!? WOW! Here is a wikipedia link so you can study up on the header wrap's ability to make the intake piping cooler because of the fact that the header wrap and aluminum are in contact with one another and the heat is reduced through the thickness of the material:
http://en.wikipedia.org/wiki/Thermal_contact_conductance
Then here is a link so you can learn what conductance even is:
http://en.wikipedia.org/wiki/Heat_conduction
Okay, the next part of my wrap is the gold reflective tape. No need to go through all the crap, all I can say is that the effect of thermal radiation is lowered because the gold material reflects the thermal radiation rather than absorbing it, in turn making the surface cooler. Here is some light reading for you:
http://panda.unm.edu/Courses/Finley/P262/ThermalRad/ThermalRad.html
Enjoy!
I used 2" and about a 1" overlap which is more than recommended, and uses a lot more wrap than necessary, but gives extra thickness which helps insulate better.
Please re-read what I wrote. I'm not arguing that the intake air temperature can't be lowered by wrapping the air intake. What I'm arguing with is that the pipe will feel cooler as a result.
The heat wrap improves insulation (the only way it can reduce heat transfer to the air in the intake), so the cool air inside the pipe has less of a cooling effect on the temperature of the wrapped pipe's outside. The only way the outside of the pipe can feel colder is if the heat transfer was improved, which is the opposite of what the wrap does.
Alright, here is a simplified scenario that you should be able to follow: you have an ice cube. It feels cold in a warm room. You wrap it in header tape to keep the ice from melting. You touch the wrapped cube. Does it still feel cold, or does it feel suspiciously like it is at room temperature?
What you are trying to tell me is that the header tape will actually feel cooler than the ice cube does by itself. Sorry, that ain't happening.
And please spare me the reflective heat foil stuff, I responded to ViRtUaLheretic's post which has no heat foil visible.
your forgetting that the cool air is at say 60-70*F while its surrounded by 190*F ambient conditions. I think it will pick up a few degrees. Sorry but its pretty sound and a old, tried and proven method.Seal a drinking straw and insulate it... pointless.
blow cool air through a drinking straw and insulate it... the cool air stays cool
I want to see IAT comparisons before/after doing this. those who argue it does something/nothing should be willing to prove their claims.
I have a ScanGauge II in my car and it measures IAT with a descent refresh rate of about one sample per second. I notice that my IAT is ALWAYS closer to ambient when it is cooler out. However, I have noticed that the gap between IAT and ambient is getting larger, hence hinting to mee that I have some sort of leak. it used to be that 50 *F, 50 MPH would yield me with ~ 50 *F IAT. the same conditions now give me ~63 *F IAT
is my intercooler plugged?
1 sample per second is a pretty slow refresh rate also 3-4/second is good.
DEI offers both woven wrap as well as gold foil.
http://www.designengineering.com/products.asp?m=sp&pid=9
http://www.designengineering.com/products.asp?m=sp&pid=75
I use their wrap on my intake as well as my entire turbo-back exhaust. (yes, from the turbo to the tips)
Thermal energy always flows from hot to cold, so if you insulate the intake pipe using header tape, less energy is transferred from the engine compartment to the intake pipe -- the temperature of the air inside the intake drops, and the engine compartment actually gets hotter because less heat is dissipated through the intake pipe.I can only tell you what I have seen so far, my intake tube is much cooler to the touch regardless of what you think or say I am experiencing this first hand.
