adech10
- Lancaster, PA
- 06' BMP GTI
About how long does this take?
You dont have to remove the tbody pipe on either fsi or tsi to get the intake manifold out. I dont need a lift for decarbs.
And for the guys worrying about the teflon seals, those NEVER leak. Anyone who says they do fucked something up with them. Youre supposed to use the wire brush in the remover/installer kit and clean the bores. The only seals that def need replaced are the orings, those will leak if ripped just a hair.
Always make sure the rail isnt double sealed, as that will leak too.
Tackling valve cleaning this weekend. Have everything removed except for that M10 Satan bolt...
Is it absolutely necessary to remove the dipstick guide tube? Does it get in the way of the M10?
Mine won't budge.
Mine won't budge.
Yes, the dipstick tube needs to go. Wrap some rope around it and yank.
I took 3 full days to get the job done last week.:thumbdown:
I found out that my M10 triple square bolt stripped when I got to it. This is going to take a while now...
Also, I wrapped a zip tie around the dipstick tube, and managed to break the eyelet off. The tube did come out finally, but with a vice grip.
