TheTroyness
I changed a tire once...
- Arkansas
Old vs. new intake manifold bracket:
Success finally.
Now just need to clean vales.
That's one way to get your manifold off...
Success finally.
Details please. Is this some form of media blasting?
Success finally.
The problem is that you wont get equal distribution to cylinders 1 and 4, cylinders 2 and 3 get most of the spray.No, I spray my own mixed solution through the IAT sensor port. It is NAPTHA or Xylene(whichever I happen to have), fuel, and mineral spirits...1 part each. I have a DIY vid, but I have since modified my sprayer so there is about 8ft of hose spliced into the wand so that I can spray from the drivers seat so I control the throttle rather than prop the throttle pedal with a stick to control the rpm's.
https://www.youtube.com/watch?v=hHF-Jdw0eto&list=UUhzboxyxcOHLU7IwZaFWg_A
I began doing this after researching all of the top end product's msds's finding that they all mostly use mineral spirits, fuel, and either NAPHTHA or xylene. This stuff is cheaper by the gallon at Lowe's or the Depot.
I have a cheap Chinese bore-scope, but it does show the reduction of build-up well enough.
I am near doing a remake of that vid ever since coming up with the wand extension rather than the stick.
I jsut went ahead and skipped reinstalling that bracket as its not needed and was such a pain to uninstall.
Your method helps, but its no replacement for a manual removal of the manifold and cleaning.
How do you come up with that? If 1 and 4 didn't get much of the spray that would suggest that 1 and 4 don't get as much air as well. This process is used on big V-8's and all the valves get enough spray to be effective. Even if it was slightly less effective, which I don't believe, this does "good enough." I'd rather do this every 10-15k miles then pulling my intake off every 50k. Talk about saving time. And time is money so I'm saving that too.
↑ If it helps, and this keeps me from ever having to do a full manual clean out, it is safe to say that it is a replacement for a manual removal of the manifold and cleaning, IMHO :drinking:Your method helps, but its no replacement for a manual removal of the manifold and cleaning
I believe there is enough distribution. I use 24oz and a nozzle that is fully tightened and sprays a wide fine conical pattern. Certainly due to a directional pattern fluctuation 2 and 3 may receive more but 1 and 4 will pull enough due to their equal volume drawn in and proved by the compression being equal across the board.
:thumbsup: I see my resulting bore-scope pics immediately after the process and it always looks good to me.I'm with you on this one. I still think people like to do more work then they have too.
↑ Well...thank you...I will.you can continue to think that...
