eurocars
5/17/15 - Never forget
- Indianapolis
- 2006 GTI
next is expansion tank delete. after that, im thinking of a eurojet valve cover an aluminum intake manifold with custom finishes
expansion tank...is that that orange filled thing on the top left of the engine bay?
great work man. I understand putting a new finish on the valve cover, but what kind of finish...powder, paint, anodizing, or polish?
That^^^ is a very tough pill for me to swallow. I've been wiring car stereos and stereo systems for a long time, and soldering is my preference. Granted I use crimps when I'm in a pinch. Maybe its different for the rest of the car wiring, but I trust a solder joint wayyyyyyyyyyyy more than I trust a crimp. If done correctly, a solder joint's wiring should be twisted together first and then soldered. So the connection is far superior to that of crimp. I can accept your reasoning of vibration, heat, etc, however saying that a crimp offers less resistance at the junction than a soldered joint, I'm just having a tough time with swallowing that pill. But hey I guess I'm thread jacking, sorry Eric.
Ninja edit: another reason I prefer a solder joint is because a crimp can actually break. Even if the solder breaks on a properly soldered connection, the twisted wiring should still hold as long as its not being pulled on with force.
From page 2 on the attached TSB:
"DO NOT solder repairs on vehicle electrical system."
and
"After crimping a repair connection, crimp connections must be heat-shrunk using hot air gun to prevent moisture
penetration."
-Cad
Haven't read this whole thread and I don't know if this applies to me, but I soldered my boost gauge wiring for the backlight to my dimmer switch, is this bad?
Sorry for thread jacking btw
You sir are properly fucked.
Nah just kiddin', your fine...
