Perpetuus
Data Encryption
- In my garage
Hmm.. I work in automotive engineering, but I certainly don't have all the answers, or know everything inside out about vehicle dynamics. My job also doesn't make my understanding of the topic any better than others necessarily. Anyway, here are the premises of I was basing my statement on. Of course, this is vastly simplified: (Alot of them from Milliken's Race Car Vehicle Dynamics book)
For making the following less complicated, I am assuming straight line driving.
1) Vehicle tires generate more grip as more force is exerted on them, up until the ultimate limit of grip the tires are capable of with respect to the road surface.
2) For driving over typical roads with undulations, dips, and potholes, etc., the car with the best grip is the car whose tires can track the road surface irregularities the best (i.e.: tire is following the surface of the road 95% of the time vs. 80% of the time with an overly soft spring/damper setup).
3) The car with the best grip is the car i) whose sprung mass (which is invariant), is the least upset by the suspension/tire combination heaving the car up and down over bumps, and ii) whose tires can track the road surface irregularities better (or rather, a higher percentage of the time). Both conditions i) and ii) are necessary to generate the best grip the tires can deliver, assuming everything else is unchanged.
An overly soft spring/damper combo or an overly hard spring/damper combo will both have drawbacks on grip and handling.
a) In the case of the car with the overly soft spring/damper combo, the sprung mass stays relatively undisturbed, especially over high frequency bumps in the road. This is good for helping keep the weight of the car on the tires as consistent as possible. However, if we look at the unsprung mass of the tire and suspension, we have an issue where the tires are not able to follow the contours of the road very well, and hence diminishing grip at the tires. Part of the reason for this is because the spring and damper combo allows the tires to ride easily over road irregularities during the compression stroke, but not necessarily during rebound, where the suspension cannot react fast enough (or with enough force from the soft springs) to allow the tires to ride on top of the road surface well enough to generate good levels of grip.
b) Now, consider the case of the car with the overly hard spring/damper combo. The combination of the hard springs and dampers will make the car feel bumpy (harsh on compression because of the spring rates might be too high for various road imperfections). When the spring rate is too high for the given road irregularity the tire is travelling over, this translates to a displacement of the sprung mass, heaving it up quickly, and hence, reducing the total effective sprung mass acting on that very tire. This is felt by a loss of control by the driver, possibly requiring steering adjustments to readjust the trajectory of the car, a loss of grip at the affected tires at that very instant, and unfavourable weight transfer induced by the road surface. The weight transfer is complex, and can be fore-aft, diagonally, or a combination of both. This unfavourable weight transfer upsets the balance of the car, the effectiveness of the tires to grip the road, and a higher possibility of the car to snap-spin during cornering. However, the unfavourable weight transfer induced the by hard springs, (which stems from the road irregularities), combined with the quick weight transfer means that the car will snap-spin much more easily during cornering, as compared to a car with less stiff springs/dampers.
Because of the increased inconsistency in vehicle grip and handling, and the higher tendency to snap-spin (especially in lower grip conditions), the car with the slightly lower spring rate/damper combo is probably better all around IMO.
Of course, the higher spring rate/damper combo makes the car more confidence-inspiring. The transient cornering response is increased, the car rolls less in turns (accompanied by less unfavourable camber change), and overall the car feels sportier to drive. From personal experience though, sometimes you don't necessarily need very stiff springs to make a car handle and grip well. In many cases, the driver will be able to feel the road alot more with the more stiffly-sprung car, which also gives the sensation of a higher speed as more vibration/bumps are upsetting the car at a higher rate, even when driving at the same speed as the same car with a softer spring/damper setup.
IMO, for the above reasons, the ideal case is a suspension system that has a variable spring rate and variable damping to anticipate the road surface ahead. This will help the tires track the road properly, while maintaining the highest possible level of grip on the road surface and translating little to no extra amplitude to the sprung mass, which tosses the body upwards and removes grip from the tire(s).
Sorry for the long post. This is my understanding of vehicle dynamics at a simplified level. We are all here to learn, but I hope this makes sense.
