KingOfBattle
- Holly Ridge, NC
- 08 GTI
Anyone running S3 or RS4 injectors on the K03? Any improvement? Would it require software or would the ecu adapt to something like that?
Thanks
Clay
Thanks
Clay
Upgrading injectors only really helps when power is limited by the injectors. With the K03, power is limited by the turbo, not the injectors.
^Its variable, rpm based max percenteges and boost based for at the moment cycle also dependent on the tuned specified AFR. Also depends on the condition of your hpfp and intake cam shaft.
:lol:
How about actually answering the question next time?
OP, I see close to 80% at highest load on APR Stage II, 91 octane file at 5800 feel altitude. I would expect 10 to 12% higher duty cycle at sea level.
