Rear Hatch Power
rolo402
08 Bunny 24/7
Los Angeles (Sun Valley) ca
Rabbit
How did you get the rubber housing off? I was able to splice one of the wires and get my hatch working again, but there's still a few cables that are worn out that I can't get to with the rubber thing in the way. :mad:
You have take all this off if you going to run me wires. I recommend that you do all the wire just cuz they will all brake and rap all the wire back up.
You have to take off the 3rd brake light to get to the connecter comes off from the top down and it has clips on the in sideImageUploadedByTapatalk1347132441.773447.jpg
Take this off it has two screws and clips ImageUploadedByTapatalk1347132515.799094.jpg
And this one has to screw I think
rolo402
08 Bunny 24/7
Rabbit
you got to take this off all clips ImageUploadedByTapatalk1347134310.453198.jpg
And sorry for the multiple post app was crashing on me
JetTurbo
geezer
South Florida, USA
2018 GTi Autobahn 6M
Yup,
but you are lucky, 2009 has removable taillight,
2007, didn't, I had to splice that one!
I assume you are referring to the Center High Mounted Stop Light?
It is not model year related, it is a Rabbit vs GTi / r32 difference.
The incandescent CHMSL on the Rabbit is removable for bulb replacement.
The LED CHMSL on the mk5 GTi / r32 is glued on.
While VWOA warranty replaces a defective LED CHMSL for 10 years unlimited mileage,
that won't help on the harness fix.
rolo402
08 Bunny 24/7
Rabbit
the rabbit 3rd brake light is LED
but yea they are not the same
chriso59
Boston
Ugh, pretty sure I have this same problem. Started up my car this AM and the MFD said that both my reverse lights were out. Sure enough my rear wiper and trunk release both no longer function either.
An interesting thing that led up to this, twice over the past week when I've been at a stoplight a low frequency "bad ground" noise would blare from my sub, I just assumed one of my sub's cables came loose. More likely it was attributable to me having the brake lights on for a long duration and a grounding issue in the wiring harness.
I'm planning to open up the rubber boots this weekend to see what's going on. Really don't want to deal with he BS of changing out the whole harness. Tho this does seem like it's a potential fire hazard and something that VW should look into if it's really widespread...
For the record I have an October build 2008 GTI with 98k miles.
chriso59
Boston
Took a look at the damage this weekend. Two wires had exposed wiring and one was completely severed. I reattached the wire and used some electrical tape to prevent shorting. Going to avoid using the hatch until I figure out what to do next.
rolo402
08 Bunny 24/7
Rabbit
Oh yea that's it
