WJ, I'm thinking of buying Michelin's PS'2 225 17 45 91Y
My current OEM Conti's are 91W, are you saying the 91Y Mich have a harder side wall = less grip?
Rocco,
It's difficult to say.
Michelin traditionally have softer side walls than the other brands.
That's what makes them grippy & comfortable at the same time.
They are also noted for being notably good in the dry.
The EVO 2007 tyre test performed with Golf GTI had the following rankings:
1. Goodyear F1 asymmetrical
2. Vredestein Ultrac Sessanta
3. Conti CS3
4. Bridgestone Potenza RE050-A
5. Michellin PS2
6. Pirelli PZero Nero
7. Kuhmo Ecsta STP KU31
8. Dunlop Sport Maxx
9. Yokohama S.Drive
Point is: I think there are better tyres out there for a lot less money.
If you're boss is paying for them - fine.
If you pay for them; I reckon the Goodyear F1 Asymetrical or Bridgestone RE001 Potenza Adrenalin - why? They are designed to work with lowered sports vehicles with extra negative camber.
Michelin PS2 are like $600.
I think the Conti CS3 are better at $495.
My first choice was Goodyear F1 asymmetrical due to -20mm ride height & -1.0 negative camber. I found with the CS2 that they worn unevenly. Haven't had this problem with the asymmertical RE001. RE001 are not OEM tyre so they are a bit noisier & ride a bit harder.
Goodyear F1 or RE001 could be had for @ $290-$360.
The Conti @ $495 or Michelin PS2 at $600 are not twice as good as the other brands. The Goodyear is likely to be better than both for wet & dry.
James my dear chap, how are you?
To put your mind at rest on our comparison runs I was running 36psi cold too.
I note your Toe in vs Toe out comments with interest - in my experience on Bargearse the fat Ford, increasing its Toe-in tended to increase the level of nervousness off-centre - does that follow from your experience in the Golf?
Good to hear from you Dingah.
I'm fine.
To answer your question - Yes.
The toe out (-.0.2mm) I run at the front is only marginal - but does have a notable effect - esp at higher speed.
When the outside tyre is turning into a corner, the inside wheel is acting like a brake which helps pull the car into the corner.
Great for tight twisties; but at high speed you have to have your wits about you.
After another 5,000km - I will check wear to see if I can get away with more toe out. I doubt it though - as more toe out (negative toe) will start to wear the tyres unevenly, causing more wear on the inside edges.
Interestingly - I experimented with the tyre pressure once going to 18"/7.5"/225/40 series tyres. I thought I would require more pressure.
I ran them as high as 39 psi - but found too much understeer at low speed turns; and too much oversteer in higher speed turns.
Now I run them at the same pressure as I ran the 17" Denvers - 36psi cold.
The heavier huff wheel does make the ride more supple & refined; but counteracts with a brittle feeling at low speed in city with less tyre & more wheel.
Cheers
WJ
