Identify Leak (Green)
mystix
Toronto
So I noticed something green dripping behind the front passenger wheel and need help identifying it.
roscoe87
Columbus
could be coolant if someones putting the wrong stuff in your car, but also check your windshield washer reservoir for leaks which is located by the passenger wheel. sometimes people use a green bug be gone type fluid.
mystix
Toronto
Its not coolant, that would be the pink stuff which is right on the line.
Its not windshield washer fluid either because the reservoir is in front of the wheel, not behind and also because I use the cheap standard blue crap and nothing fancy.
kyle_h
Canada
How's your ac working? Ac oil could be green if there's dye in it
Sent from my iPhone using the Tapatalk app, so that explains the typos...
mystix
Toronto
My pressure switch failed just over a month ago. I replaced it and had the system refilled by a mechanic. The A/C has seen been working fine since, no loss of cooling.
bowerhour4334
SoCal
MKV GTI
So youre saying its not your coolant. Its not your windshield washer fluid. Its obviously not your engine oil or trans lube.
The only other liquid in the car would be fuel and whatever is in your cup holder.
Das Gespenst
Glen Ellyn
If its oily, its R134a. our A/C lines run right there and connect at the condenser mounted in front of your radiator. The green comes from the oil/dye used to lubricate and identify leaks in the A/C system. There are only 6 fluids in our cars, its not 5 of them (easy to tell by color), so start looking, if there is that much it should be easy to trace.
Start at the condenser, it looks like a mini radiator, the connections are on the passenger side behind your grill. From there just start tracing the lines, if you want to go all the way with it. Pick yourself up a UV flashlight, the dye is UV reactive and will glow neon under the light, makes tracing and finding the leak easier.
Wild Hare
.: MR. BIG STUFF :.
Nortvest
2015 Golf R (TUNED)
Pee
Austin_hull
Für Die Liebe Des Autos
Virginia
MK5 TR GTI REVO// +
You mean coolant?
Its coolant. However vag specific coolant is usually like pinkish. But yeah its coolant check your levels.
yup, that's exactly what I meant, but I figured if the OP was asking about something that simple, that perhaps they weren't familiar with the proper terms...but yeah, Coolant.
:thumbsup:
mystix
Toronto
It's possible it could be PAG oil. The AC is still working cold though, do these systems have a pressure blow off valve in case they are over charged? Perhaps the shop which re-charged the system over charged it?
I suppose if it's PAG oil then I should have it fixed before black death kicks in.
goneD4rk
underground
do the taste test. Let me know what you think.
mystix
Toronto
Gonna have to wait til next time when I see it leaking. So far I haven't seen it again. I should have at least touched it to feel for consistency.
