Recently after getting a "Low Oil Pressure" warning on my stock '09 GTI I took it to my friend's shop (not a dealer). He thought it might be a clogged oil pump after manually checking the pressure. The next day he pulled the oil pan and found metal shards in the oil. None of them larger than a millimeter. I don't know much about GTI's let alone cars in general. He told me that I may need a new motor! not too happy..
Yesterday I called the local dealer in hopes to see if there was some sort of warranty extension on this issue as there had been on my air intake a couple months back. However there was not and even though my '09 GTI has less than 60k on it, it still doesn't fall within the 5 years so it seems as though I'm out of luck.
I have babied this car ever since I've gotten it and have changed the oil on it every 5k miles. I cant believe that I did anything wrong or drove it hard enough for anything to happen on my accord however I understand these sort of things may still happen.
I have my father-in-law helping me with my options as he knows cars very well however he does have limited experience with VWs. So I am asking you all for advice/help with what the next step is that I should take on this matter. I had the thought of flushing everything out and re-filling it with new oil. Cleaning out the pump and all and driving it for a weekend, then following it up with checking for metal shavings again. We have found some engines on eBay that are listed "2008 2009 2010 Volkswagen Jetta 2.0L Engine Motor 75K OEM" incase we do have to replace them. They say they fit GTIs however I'm not so sure since we've seen others specifically listed for GTIs for around $2500+.
My engine is a TSI with the engine number CCT 060927. Any help on this matter would be greatly appreciated. Let me know if there is anything I missed. I sincerely thank you for your time in this matter.
