Syxx Shotter
Has an "S" on his chest
- Chuck, SC
I had an extra breather tube laying around so I figured I would mess it up to show the guys on here who wonder how this is done.
1) Remove the rear breather tube using these directions http://oooo-a3.blogspot.com/2008/03/pcv-replacement-and-eurojet-valve.html
2) Look into tube to see if you even have the check valve; if it looks like this inside on the top forward you have the check valve. The red arrow points to the check vlave; this is all you want to remove. NOT ALL THE PLASTIC JUST THE SMALL VALVE
3) Put a decent sized phillips screwdriver against the check valve.
4) Hit the handle of the screwdriver until the valve pops loose. This doesn't take alot of pressure; I did it with my hands.
5) Check to make sure all the parts broke out and aren't hanging loose. If they are remove them. Your should look like this now.
6) Shake out all the parts. Should look something like this.
7) Valve successfully removed.
8) Reinstall with the directions you used to remove it.
Hope this helps someone.
