Tmsracing37
Boosty McFlamin Job
- MD
- 06 GTI
First off - The main goal is NOT more power. I am looking at proper calibration, not number hunting.
So after being told Maestro will not work(at least thats what I first interpreted it as when he said it is a waste of time)... TMS, or Cruizin, you are saying that Maestro is what you use? And you can read/edit/write the entire stock calibration? Is there any datalogging functionality missing from this software? In other words, does this vehicle have PID's defined that for some reason may have issues or give bad data through this software? I am looking at the Eurodyne software supported vehicles list, and my car says Map Switching: NO. Do they mean reflashing, or is that regarding some kind of signal modifer (on-the-fly tuning is what some people call it).
TMS, Cruizin, hopefully this all makes sense for you and you can give me an answer. So far what I have read doesn't seem to make sense as I am getting what appears to be conflicting information.
So much fucking text. I expect no one to read any of this. Please, nothing to see here.
Maestro shares the same principles as EFI live, Hp tuners, Cobb AccessTUNER, etc... Not as user friendly, but that's partly due to the nature of these Bosch ECUs and the logic it uses. There is about 50-60 tables and parameters you can edit and fine tune with Maestro 7 for the Bosch MED9.1 and MED9.5 ECUs. As some of us continue to work with Chris, more tables/parameters are being release to the public. (example I have about 10 new parameters for the MED9.1 115b ECU and in the process of testing those, before he releases them).
You will not be able to read your current APR tune and edit it. You have to write over it with one of Eurodyne's base files, then you can edit/write those files. Yes, there enough tables/parameters for you build a file and fine tune it to your liking.
Yes the Suite, does have data logging capabilities and those logs can be used for map tracing and building histograms which can help you make decisions on certain edits.
No, on the fly tuning. If you make any change, you have to rewrite to the ecu.
http://www.youtube.com/watch?v=CTnNfnThDO8
