redbarron04
- Corinth,MS
- 07 gti ko4'd
Ok guys so I put my new clutch in this weekend I went with a stage 2 spec, go ahead and start hating haha. Ok so I started to put everything back together finally after all the headache of getting the trans to line back up. Went to go ahead and start bleeding the clutch. It will build a little pressure but no where near even factory resistance. When opening up the bleed valve it shoots fluid out still but no much or with much power. When you are close to the bleeder block with someone else pumping the clutch attempting to bleed it. It sounds as if it is sucking air into the lines at the valve. I have tightened it down all the way to where it won't turn anymore. I know that there is o rings in the bleeder block and some people are having trouble with it sealing it well. Can someone tell me anything about this. Thanks guys txt me for any more info or if you have any idea what to do. 6626035350
