3szoom
- Algonquin, IL
- 2008 UG GTI
I tried searching for this but couldn't find the exact answer I'm looking for.
I just changed my cam follower this afternoon following the Dummy Proof directions. Everything went fine but when I tried installing the new follower I couldn't quite get it to go in.
What I ended up doing was using the spring on the fuel pump to push the cam follower and then used the bolts to torque it into place to spec. Everything fit fine and I proceeded to get everything back together. I primed the pump about 5 or 6 times and the car started fine and runs great.
I'm being kind of paranoid here and I just wanted to make sure that I won't destroy the cam by the way I installed the follower. Thanks!
