avenali312
- Mableton, GA
- 2015 GTI
Hey all,
I went to check my cam revision and found a nice little surprise. Top two bolts were fine and loosened easily. The third, lower one... not so much. It looks like someone in the past molested this bolt head. It's now essentially just a round hole. I can't even tell if it used to be a torx or Allen head.
The weird thing is that I ordered a new bolt from the dealership so I can replace it when I do eventually get it out, and the one they gave me does not look like the current one. It looks the same as the upper two bolts. The bolt in question is the one that holds the bracket for the wire loom in place. See photo below.
What I need is advice on removing this thing. I wanted to go the route of Dremel-ing a slot into it for a screwdriver, but I can't get the Dremel in there, even with the battery out.
Any help is greatly appreciated.
Special thanks to danman132x. I hijacked your photo and drew on it.
