I've been trying to install a MKV R32 fuel pump into my 2008 GTI (meant as an upgrade to support my new K04+ tune) and running into all sorts of problems with the installation.
So far the fuel lines on the pump have been a total bitch to deal with.I had to cut the retaining ring to be able to get it on around a fuel line that wouldn't come off the new pump (I put a fuel line back on before I remembered I needed the retaining ring first), and now the white top of the pump isn't going down far enough to seat itself where it's supposed to seal with the tank. It's sticking up about an inch too high. This pump is a tota PITA to install, and I don't know why it isn't seating properly.
Has anyone actually installed one of these? Is it supposed to fit without having to modify the "roof" or stilts part? Why won't it seat?
The R32 pump looks quite different from the MKV GTI pump. It has three corrugated tubes, one of which I blocked off hoping it's the crossover tube. The GTI pump only has one line, and what looks to be a vent tube. I'm not sure how the R32 pump's tubes/lines are supposed to connect with the fuel lines of the GTI itself. The GTI itself has a blue fuel line and a black one. I'm not sure how these should plug into the pump. Can anyone help with this? Like I said, the R32 pump isn't all that similar to the GTI one, so looking at the two didn't tell me much about how to connect fuel lines to the new pump.
I've searched like crazy and haven't found much information, or pictures of other people installing the R32 in-tank pump as a replacement/ upgrade in a GTI, and I'm in a bit of a panic since I need to get my car up and running tomorrow. If you can answer my questions or post a link that has useful picture, that'd be a big help. Thanks in advance.
