Arin, if it helps, i just pulled the car onto a lift and tested the N75 solenoid w/ an ohm meter.
apparantely it's supposed to read between 20-30 ohm but it read nothing. i think my n75 is bad.
i've also tested just about every inch of the car for boost leaks, so unless someone drilled a hole in my intercooler i don't know where the hell it's coming from.
also you all know the sounds of a boost leak, very distinctive, however i'm not hearing it from any angle of the car.
all i get is hearing the turbo a little loud, not like compressor wheel play, just overworked turbo. no symptoms though of a bad turbo; i hear when they go it's pretty obvious.
