Hi,
i used to have 08 GTI and had stage 1 bluefin with no problem..i bought a 09 GTi because i had an accident with my 08 and decided to go for stage 2 so i went for Milltek TBE and K&N Typhoon and got the stage 2 software from bluefin
from a couple of days i got a vagcom and decided to run a scan and found this:-
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H83NB91N
Coding: 040300101C070160
Shop #: WSC 66565 257 00032
1 Fault Found:
000135 - Fuel Rail/System Pressure: Too Low
P0087 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 9
Mileage: 2929 km
Time Indication: 0
Date: 2000.00.00
Time: 13:49:02
Freeze Frame:
RPM: 2942 /min
Load: 76.4 %
Speed: 100.0 km/h
Temperature: 91.0°C
Temperature: 53.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Readiness: 0000 0001
then i contacted superships to see whats wrong...
Michael Alvey-Anderson:-
This error message can occur if the car is running too much boost for the fuel system to supply the required level of fuel. Can you send me some logs across of a full throttle run in 3/4th gear from 1000rpm, measuring the rail pressure (230) and boost (115) and ign (2 or 3).
Based on this I can advise further. Thanks.
then i made what he asked me to do and then he send me a revised file...then i made extra runs to check if there will be any difference
i found the values are the same...so i contacted him again with the logs
then he send me again a revised file and GUESS WHAT i made some runs and the value are almost the same with these huge fluctuations in rail pressure values
so please anyone can check the attached logs and care to advice?
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 2929 km
Time Indication: 0
Date: 2000.00.00
Time: 13:49:02
Freeze Frame:
RPM: 2942 /min
Load: 76.4 %
Speed: 100.0 km/h
Temperature: 91.0°C
Temperature: 53.0°C
Voltage: 13.970 V
