Dredknut
DSG Fart Fanatic
- Its not important...
- 2007 GTI
I am going to describe my situation in as much detail as possible, so forgive the lengthy post.
SITUATION:
Recently I have been getting the feeling that the car has a minor boost leak. Approximately 5000km ago, I chipped the car with APR Stage 1. I typically run the 91 octane file, and occasionally run the 93 octane file. According to my boost gauge, when I initially got the chip while running the 91 octane file, I would briefly peak around 20 psi and level off around 16-17 psi towards redline. Recently, I have noticed that I seem to be peaking 19 psi and holding approximately 15-16 psi to redline. I can't hear any hissing under the hood outside of normal engine noise.
Now we all know how innaccurate and inconsistent mechanical boost gauges can be, and I am aware of this fact. However, if you consider these numbers relative to one another, I feel like I have developed a boost leak somewhere thats causing me to lose 1-1.5 psi.
I will *hopefully* have access to a vagcom cable in a couple weeks, so I can definetively determine if my actual psi levels are meeting specified. In the mean time however, I am hoping that some of you can shed some light on possible locations of a potential boost leak, as well as offer some insight into my boost gauge situation.
MODS:
2007 GTI with DSG, 82000km on the odo, relevant mods as follows:
- APR Stage 1
- AWE Vent Mounted Boost Gauge
- Neuspeed P-Flo
- BSH DV Relocation
- BSH Boost Tap
- BSH Stage 1 PCV Fix
THINGS TO CONSIDER:
Firstly, I purchased my boost gauge second hand off of a forum member on here. The needle has never really sat right on "0" and as time has gone by, the needle has migrated farther from the "0" when the car is turned off. Here is a pic to illustrate what I mean:
My first question is: Would the fact that my needle doesn't sit directly on "0" affect the PSI and inHg readings the gauge gives? ie. if the gauge is about 2mm off of "0", will all of my readings be the same 2mm off? My assumption to date has been YES, however I figured I would throw it out there. I have had this gauge installed for a while, long before I was chipped. The needle has always been "off".
When driving, if I let off the gas completely and let the car coast, my gauge doesn't sit right at -20 inHg, more like -17inHg or -18inHg. This was the same before and after I got chipped. Here is what my gauge looks like when coasting:
When I am stopped and idling at a light, my gauge will read slightly higher at -15 to -17inHg. This was the same before and after I got chipped. The reading varies, however this pic shows about the lowest inHg value my gauge will read when the car is idling at operating temp:
Considering my gauge is off to begin with, do these inHg values seem normal? My opinion so far has been that my coasting inHg is normal because of the needle being off "0" to begin with. However, my idle inHg has NEVER been as low as coasting... Is this normal? Does anyone else with a properly working boost gauge and no discernable boost leak have the same readings?
WHAT I'VE CHECKED SO FAR:
This is what I have checked so far in hopes of identifying a boost leak and fixing my gauge readings:
- OEM IC hoses. I got under the car and checked the connections here. My understanding is that there is some play in the OEM "snap fit" connections with that wire ring thingy... My hoses on both sides of the IC both were able to move about 1-2mm with the wire snap ring in place. This play is normal and wouldn't cause any boost pressure to escape, at least thats what I have read. Is this true, or is this "play" in the connections potentially causing boost pressure to leak?
- Boost Tap and Vacuum Line connections. I am confident that all of the connections associated with my Boost Tap, Boost Gauge and Forge DV are not leaking. I have replaced these connections numerous times for various reasons, and my gauge readings have remained the same.
- BSH PCV Block Off Plate. I have removed the plate and repositioned it, and checked the gasket for leaks. I have re-tightened the OEM screws that fasten it to the plastic valve cover, as much as I dare in fear of stripping the plastic. I did notice however that there is a small gap between the valve cover and the BSH plate on the upper passenger side. This is not due to the design of the BSH part, it has to do with the fastener locations. Here is what I mean:
The gap is approximately 1mm at its widest point. This plate is torqued down as much as I dare, however if you look down that space you can see the OEM orange PCV gasket. If you look at the plate closer to one of the fasteners, the plate makes contact with the valve cover, there is no space and the PCV gasket is not visible. Would this gap potentially cause a boost leak? My guess is no as the 100's of people out there with any aftermarket PCV solution would all have boost leaks... However, given that I can easily see the gasket, wouldn't it be easy for boost pressure to escape here? Does anyone else have this gap?
THINGS I HAVEN'T CHECKED:
Rear PCV. Visual inspection looks fine, however is there any chance that if my rear PCV has failed, that I might experience a boost leak? Is the rear PCV even functional beyond being a pressurized tube if you have an aftermarket PCV block off plate installed? The rear PCV is the tube with the ring clamp on it in the middle of this pic:
IN SUMMARY:
These are the questions I am looking to have answered:
- Would the fact that my needle doesn't sit directly on "0" affect the PSI and inHg readings the gauge gives? ie. if the gauge is about 2mm off of "0", will all of my readings be the same 2mm off? Are my inHg readings normal given what I have described above?
- Are my APR Stage 1 boost levels normal? Should I be peaking 19 psi and holding 16ish to redline? More? Less?
- Would any 1-2mm of "play" in the OEM IC "snap fit" wire connections potentially causing boost pressure to leak? If so, is there a way to DIY fix this or should I consult my dealer?
- Would a 1mm gap between between the BSH plate and the valve cover when the bolts are fully torqued down cause a boost leak? Does anyone else have a gap?
- Is there any chance that if my rear PCV has failed, that I might experience a boost leak? Is it worth removing my intake and MAF heatshield to check?
Thanks for taking the time to read and any insight anyone can offer would be awesome... I know its hard to diagnose if something is wrong without logs, but I will hopefully have some done asap and get them posted. I don't know if this is all in my head or if I infact to have a minor boost leak somewhere...? Or perhaps my gauge readings are making me worry without cause... :mad0259:
SITUATION:
MODS:
- APR Stage 1
- Neuspeed P-Flo
- BSH DV Relocation
- BSH Boost Tap
THINGS TO CONSIDER:
IN SUMMARY:
