Mystery Noise From Intake
TheTroyness
I changed a tire once...
Arkansas
What the hell is this noise?
I had an AEM Stage II CAI that went down into the fender well, and I thought the noise was the intake rattling on the frame or something, because the sound was coming from the end of the intake. So I took the Stage II part off only to find the noise isn't from the fender well area where I thought it was. It is, in fact, coming from the end of the pipe. I guess the sound is resonating down the pipe.
At any rate, I wiggled the intake in all sorts and it isn't rattling. I have no idea what this noise could be, but it's incredibly annoying. It only occurs sometimes. Usually, it happens when the car first starts when the idle is slightly above 1K, but goes away once the idle drops only to intermittently reoccur at certain RPMs and under certain conditions unknown to me.
I'M SO CONFUSED AND IT'S DRIVING ME CRAZY!
On a side note, Imageshack has been processing this video for several hours now after successfully uploading the video. It doesn't show up in my media and I can't link anyone to it. Tinypic took a few minutes. What are you doing with my video, Imageshack?!
TheTroyness
Arkansas
I think I'm going to check to make sure my exhaust isn't loose. Maybe that could be rattling or something... Any other ideas?
Sent from Outer Space using Magic!
tmw2442
SC
Sounds like the check valve in the rear PCV opening and closing, check to see if any lines to your catch can are clogged or restriced at all.
TicoMkv
Florida
Hey I´ve just posted about the same problem, I have the exact same weird noise and I detected it after a track day last weekend. I suspect It might have something to do with the BSH PCV block off I recently installed. But please if you figure it out let me know!!
ballsdeep
i pinched the hose on the return side of the cc and it stopped, i let it go and it was knocking again. ill check the rear pvc when i put on my dp.. i dont wanna jump in there twice, prolly next week its snowing here... so ill let u know if that fixes the problem.
TheTroyness
Arkansas
Awesome! I look forward to your results!
vwbulla
chicago
its the rear pcv valve.. its a valve that moves back and forth fast making that noise.
so remove it or deal with it. like me.
TheTroyness
Arkansas
Bump for update?
