0bLiViOuS
- Orange County
Ok good to know! Did you ever add in more tranny fluid?
The pressure plate and the disc are the same for mk6 and mk7, the throwout bearing and the bolt kit are different. I agree with the flywheel rattle, however it didn't exist prior to replacing the clutch, so I don't understand why it's there now. As far as grinding, it's the metal part of the bearing grinding against the pressure plate, I'll take pics once I take it back apart.
can't wait for the pic porn
I'm just surprised that your burnout situation was actually not as bad as mine was!
Damn that grinding sound *shudder*
The rattling sound though; for me, the whole car really vibrates, and i mean like it's a god damn train vibrating because I engaged the clutch at too low RPM with a stiff engine. If your rattling sound doesn't come with REAL obvious powerful vibration making you think (like in the 034 dogbone thread) that "something MUST be broken"), then it's probably unrelated.
I'm pretty sure I got the one on the left as well for my stage2+, are they sure it's the wrong one??
Did you reuse your stock flywheel or ordered a new OEM?
My clutch is slipping and I'm at 22000 miles. I'm on a budget so I didn't want to buy a new flywheel if I didn't have to thanks. Thanks for the write up!
