Kishon
- South Africa
- MkvGti
Hi,
Anyone have this head unit and is it any good? Its called the Knight Rider. here are the specs, Mine is on order and awaiting delivery. Looked good so i grabbed it.
At a Glance...
Android 2.3 Car DVD Player
Support both 3G and Wi-Fi
2-DIN in Dash car DVD player
Powerful GPS chipset
Bluetooth-enabled
Region-free DVD player
8" LCD Touchscreen
4GB Free SD Card included
Compatible with top GPS software
iPod video and music compatible
Picture in Picture function
Manufacturer Specifications General
DIN Size: 2 DIN
3G: WCDMA SIM Cards (Dongle Included)
WIFI: 802.11 b/g (Dongle Included)
Max audio output: 60Wx4
Signal-to-noise ratio (SNR): >85dB
Preset EQ: POP, ROCK, CLASSIC, FLAT
Video Systems: PAL, NTSC, SECAM, AUTO
Bluetooth
RDS System
AM Frequency Range: 522-1710KHz
FM Tuning Range: 87.5-108.0MHz
Language: English, Chinese (simplified), Chinese (Traditional), Russian, Italian, Turkish, Japanese, German, French, Portuguese, Thai
Operating System
Android OS version: Android 2.3
Android CPU: TCC8900 ARM11
Android Processor Speed (max): 720MHz
Android RAM: 256MB
GPS Motherboard: Panasonic MN101EF31G 8-bit MPU
GPS CPU: MST 776
GPS Processor Speed (max): 500MHz
GPS
Receiver Module: SiRF
Signal Channels: 62
Built-in Antenna Type: External Power Source Porcelain Antenna
Built-in Antenna Current: 15mA
Built-in Antenna Voltage: 3.3V
Built-in Antenna Gain: 27dB
Frequency: 1.575.42GHz
C/A Code: 1.023 MHz
Data update rate: 1Hz
Tracking Sensitivity: -161dBm
Position Sensitivity: 3.0m CEP
Data Update Rate: 1Hz
Recapture Time: 0.1s
Cold Status: 35s
Warm Status: 32s
Hot Status: 1s
Maximum Position Altitude: 18000M
Maximum Speed Rate: 515m/s
Speed Rate: 0.1m/s
Maps: Via SD card
Voice Navigation
GPS menu languages: English, Chinese (Simplified), Chinese (Traditional), German, French, Italian, Spanish, Portuguese, Russian, Polish, Turkish, Arabic, Korean, Japanese, Danish, Dutch, Swedish (The actual voice and display language depend on GPS software which being used.)/li>
Display
Screen Size: 8 Inch
Resolution: 800x480
Tilt angle: 0-90 Degrees (Button Activated Motorized Tilt)
Display: 16:9
Picture in Picture
Resistive Touch Screen
Memory
Internal: 2GB
Micro SD Card Slot Supports up to 32GB (4GB SD Card Included)
Media Formats:
Video: MP4, DivX
Audio: MP3, WMA
Picture: JPG
Discs: DVD, CD, VCD, SVCD, MP3, WMA
DVB-T: MPEG-2, MPEG-4
DVB-T
Digital TV Receiving Standard: MPEG-2, MPEG-4
Automatic and Manual Search
Display: 16:9
Ports
IPOD Port
USB Port
Micro SD Card Slot
GPS Antenna Port
DVB-T Antenna Port
Radio Antenna Port
RCA Audio OUT (front L and R)
RCA Audio OUT (rear L and R)
Aux-L IN
Aux-R IN
Subwoofer
Video IN
2x Video OUT
Camera IN
Dimensions
Size: 220x130x170mm (L x W x D)
Weight: 2398g
Product Notes
This DVD Player is Region Free
To ensure your safety, the driver shall not watch TV or video or operate the player while driving for it may distract the driver from driving.
This product supports the DVB-T digital TV standard, which is not used worldwide. Please check to see if DVB-T will work in your region: [http://en.wikipedia.org/wiki/DVB- T]
This Car DVD is suitable for Volkswagen (2003-2011)models including, Jettat, Sagitar, Caddy, Touran, magotan, golf 5, golf6, Tiguan, PassatB5, B6, EOS, CC, Scirocco, SEAT Leon, Fabia, Polo, VW T5
This model is compatible with most brands of GPS software - however hardware specific software such as Garmin may not run on this unit. . Any software installation you undertake should be performed or supervised by a professional.
Package Contents
Android Car DVD player
Remote Control
Wi-Fi Dongle
3G Dongle
GPS Antenna
DVB-T Antenna
Male Apple Connector
Micro USB Male to Full USB Female Cable
USB Male to full USB Female cable
AV Cables
Stylus
4G Micro SD Card
Power Cables
User Manual
Mounting Brackets
CAN Bus
At a Glance...
Bluetooth-enabled
8" LCD Touchscreen
DIN Size: 2 DIN
Bluetooth
RDS System
Operating System
Android RAM: 256MB
GPS CPU: MST 776
GPS
Signal Channels: 62
C/A Code: 1.023 MHz
Cold Status: 35s
Warm Status: 32s
Hot Status: 1s
Speed Rate: 0.1m/s
Maps: Via SD card
Voice Navigation
Display
Screen Size: 8 Inch
Resolution: 800x480
Display: 16:9
Picture in Picture
Memory
Internal: 2GB
Media Formats:
Video: MP4, DivX
Audio: MP3, WMA
Picture: JPG
DVB-T
Display: 16:9
Ports
IPOD Port
USB Port
Micro SD Card Slot
GPS Antenna Port
DVB-T Antenna Port
Radio Antenna Port
Aux-L IN
Aux-R IN
Subwoofer
Video IN
2x Video OUT
Camera IN
Dimensions
Weight: 2398g
Product Notes
Package Contents
Remote Control
Wi-Fi Dongle
3G Dongle
GPS Antenna
DVB-T Antenna
AV Cables
Stylus
4G Micro SD Card
Power Cables
User Manual
Mounting Brackets
CAN Bus
