Strieg
- Central Cali
- 2008 GTI BPY
Another weird thing is the MAP readings for boost are about 6 psi lower than gauge indicated.
Mine is the same, I have an Awe boost gauge, with a BSH tap. And an OEM 3 bar map sensor in a CTS throttle pipe.
As for my pressure, I'd have to recheck my original file logs, but I was down on fuel (for power making purposes) due to being on 91 oct and stock injectors. Everyone claims you can go k04 on stock injectors, and you can, but with 91 oct you need increased fuel press to get lambda numbers where the comp likes it, and won't cut power. That's why I'm thinking of switching to either s3 or rs4 injectors.
But, iirc, my fuel press was at 134.99 for spec and updated file put me at 139.99. I'll check.
k04 and stuff.
