GodSquadMandrake
Radioactive Rotary Rocket
- Minneapolis
Yeah it certainly seems that most people are at least running the stock FSB.
I'm wondering why almost everyone seems to be against setting both front and rear (aftermarket) swaybars on "hard". Why do the manufacturers have a hard-setting on the FSB if it is never to be used?
You just gotta watch out for a failure in the component between the seat and steering wheel. Sometimes the driver gets used to driving a certain way and is comfortable in that feeling and unwilling to make changes that make the car faster. That's fine, it's your car, but sometimes there are faster configurations. They just might be beyond your comfort zone, understanding or "butt dyno".
Very true. Also, I feel like some experience improved turn in or a little less roll at street speeds well below the limit and pronounce the handling to be much better. Feel below the limit might be more to your liking but it doesn't mean the car is faster or more controllable once pushed a bit. If that made any sense...
and had installed poly bushings on the rear control blades, which added quite a bit more rear grip.
My sway bars are 24mm solid adjustable whitelines.
Initially I set the front on soft and the rear on medium.
When I got some bsh end links for the rear I set it to hard.
Both of these were improvements over stock, but when I set the front to hard I was kicking myself for waiting so long.
But I don't race - it's just an overkill daily driver.
.:Sent by pneumatic tubes
It really depends on how the rest of the car is setup. It can help immensely with traction through and out of corners. If the car "floats" a little but ultimately takes a set and has more traction I'm happy with that trade off. On my largely stock suspension a3 it helped and I kept it off until I sold the car. Turn in was still good, the car had more front grip in most situations and could get the power down earlier and harder. If I was running r comps, with properly sorted suspension geometry wise and spring rate wise it likely wouldn't have been a benefit. But trying to make a compromised setup better with what you have on hand...this could help.
I understand the 034 bushings are spherical and you had poly bushings, but how was the NVH from the upgrade? Any other downsides?
