I am trying to understand fueling. The generally accepted lambda is .88 tapering to .8-.81 near redline, correct or did i read/hear that wrong? I have edited these two tables, but am unsure if there are others that i need to edit to add fuel.
Can someone shed some light on how i go about adding fuel at initial boost target and tapering down?
There should be a full load air temp table. You can make that match your "Full Load Lambda" table except for the very first cell. That will make fueling tuning more predictable. You can go back and mess with the air temp table later if you want. Use the Maestro thread in the R section.
