You can flash right over what you have. I flashed right over my APR. ED told me it was fine when I asked.I just want to confirm before i flash tonight, If i am going from OTS map to Maestro files, do i need to flash back to stock first? Or can i flash the Maestro stuff over the current loader and map. Probably best to go back to stock yes?
Is it getting cooler there? Maybe 28 psi setting and cooler weather is beyond what the stock map can read?Does anyone here actually run the ED is38 file for GTIs?
I'm no longer on that file, but last night I put on 28psi on the slider, and my tap was reading nearly 31PSI across almost the entire rev range. I'm surprised the thing survived. Has anyone else noticed that map overboosting quite a bit?
I dropped it to 26/27 and it was fine. Very strange
Ha I think that's even noted in other Matt's YouTube video. It's like an absurd number or something.That file doesn't have the max turbo pressure ratio set, which is absurd and dangerous for anyone at altitude
The IS20 is 9.2xx or something like that.Ha I think that's even noted in other Matt's YouTube video. It's like an absurd number or something.
I just want to confirm before i flash tonight, If i am going from OTS map to Maestro files, do i need to flash back to stock first? Or can i flash the Maestro stuff over the curre fnt loader and map. Probably best to go back to stock yes?
Look at you! Talking all maestro and shit...Got it loaded earlier and I was able to just flash the loader and base file over the current ots stuff. I’m going to pull a log tonight set on 25 psi and 92 oct and see how it looks compared to the ots stage 2 set at 25 psi 92oct. compare boost curve, ignition and fueling and probably richen the initial boost hit. It was running .99-.98 on the ots file up until about 4300-4500, I don’t think it can hurt to add a bit more fuel early on and that appears to be the norm on most logs I am seeing.
You're gonna enjoy it.Haha nahhh just the basics [emoji16]
Anyone got any idea what could be causing overboost?
This is stage 2 maestro set at 25 psi 92 oct.
https://datazap.me/u/whitemk75/nov-7th?log=0&data=1-4-7-18-19
