Success
I finally got my car put back together after finding a worn through high pressure fuel pump follower. Which ruined the cam.
The only hiccup in the whole thing was putting the timing belt on one tooth off. This happened for a typically German reason which I will show you in a minute.
To recap - new high pressure fuel pump, new intake cam, new timing belt, new timing belt tensioner, timing belt rollers, metal impeller water pump, new accessory belt tensioner and belt, new spark plugs.
Now you are probably thinking DMFRacer is an idiot and moron - how could he possibly screw up the timing belt install. Doesn't the cam and and the crank have top dead center markings - you just line them up and pull the old belt off and put the new one on.
WRONG!
It typical dumbkopf German fashion the Krauts that designed this system put the top dead center marks on the crank PULLEY and the lower timing belt COVER. Both of these things have to be removed to get to the timing belt.
So, when you are trying to reinstall the timing belt there is no way to know where the crank is in relation to the exhaust cam. Give me an AMEN if you've been here before!
Yes, you can mark the crank gear and the block, but the problem is that still leaves just enough room for error to get the timing belt one tooth off.
When this happens you are likely to get a check engine light and code P0016 which means that the engine speed sensor and the cam position sensor have an argument. If you are only off a tooth it won't hurt anything, but it will throw a code and the engine will be way down on power as the ECU basically goes into limp mode.
