ferasGTI
- VolksWagen
Thanks it is awesome procedure , I wish to learn more creative things from you
3/8 ID. It seems almost too small but I hope the smaller size will allow for less build up.
There is a spot in front of the passenger side engine mount, ill put it there and as low as possible to again hopefully promote better draining of the lines.
I hope I wont need to do very much in winter to keep everything from freezing. A buddy of mine here in Winnipeg with a BSH stage 2 had one of his lines freeze. Very little water made it into the can. I hope angling all the lines to promote draining will help things.
Still good, I don't think its going to let go.
At CT it should be in the same section as the gasket silicone, locktite, epoxy, etc.
-Cad
