Delayed boost when cold?
-SnowMan-
Denver, CO
I found one thread with no certain answers.
Cold starts, or even if the car is semi warm but has been sitting. After the car reaches operating temp, if I try to hit boost, it lags until like 4k rpm then hits like a freight train.
Feels like if you were to blow through a straw with the wrapper wadded up in it. Once you blow the wrapper out its easier to blow.
After about 5 minutes of driving at operating temp it is fine, no more hesitation.
Any ideas?
I'm swapping the coil packs and air intake tonight just because I was planning to do so anyway.
I swapped in a Rev D dv two weeks ago. This problem started a few days ago.
Sent from my Nexus 4 using Tapatalk
-SnowMan-
Denver, CO
Nothing?
Intake and coil packs went well.
I guess I will remove my DV and grease it?
Ich_Will
Land of 10,000 lakes
'08 GTI
I had similar boost issues intermittently. I had a nick in the wiring to the MAF sensor. Pull off the plastic wire wrap and have a look. Took me forever to get to checking that. I tried everything else's...new MAF,intake of to inspect, new coil packs...
-SnowMan-
Denver, CO
vagcom scan
Thats my next step.
Interesting. I just pulled the DV and cleaned it and greased it with Mobil 1 Synthetic Grease. No change.
Ill check the MAF. Thanks for the idea.
What did you do to fix it?
-SnowMan-
Denver, CO
Sticking N249?
Not familiar with that? I was thinking maybe the N75 valve.
Im gonna buy a OBD2 to USB cable and use Vag Com Lite to run a scan and see if there are any hidden codes.
-SnowMan-
Denver, CO
zrickety
The Fixer
Unknown
VW GTI
How many miles and do you suspect carbon buildup? The scan will definitely tell more. A little cheaper than vcds and better than autozone, you can get an obd bluetooth adapter. I got one for the torque app, but it also comes with it's own app that I would say is even better.
http://www.obdlink.com/lxbt/
707Stang
I'm Hella From Nor*Cal
Nor*Cal
Ive got a cheapo pocket rocket we can scan it with. It usually kicks up static and pending codes.
-SnowMan-
Denver, CO
I do suspect some carbon build up, Ive got 61k miles.
Im gonna buy a 409.1 cable for 10 bucks on Amazon and use VCDS Lite (the free one).
Already had it scanned at Autozone with their OBD2 scanner and nothing came up.
707Stang
Nor*Cal
Oh, ok. If you suspect carbon, you could try an intake cleaner that will run through the IAT hole. Napa has BG stuff. That works rather well.
-SnowMan-
Denver, CO
I was gonna do the 2 part Mineral Spirits 1 Part Fuel mix that someone else on this forum has a how to video on. Probably gonna do it this weekend.
707Stang
Nor*Cal
Ok, i just got an n75 diag schematic if you want it. Idk if its on here or not
