badboy
- Singleton Australia
- GOLF GTI MK V
I've never used ramps, what about a trolley jack and jack stands, or isn't that as safe?
who is this imposter lima?!
:lol:
Ahh yes, that's the other benefit so you can take the wheels off. I wouldnt mind cleaning mine inside one day every so often and just take them all off at once. Not sure i'd go to that level of detailing but would be ok. pretty handy if you do your own brake work.
There were 27 incidents identified where a vehicle killed a person who was working under it. Of these 27 persons killed, 20 were carrying out home duties (car repairs) and seven were regarded as being at work.
Fourteen of the 27 fatalities resulted from a car falling off the jack that was supposed to be supporting it. In most of the cases, the precise reason for the car falling off the jack was not known but investigators speculated two main possible causes: firstly, the jack was being used to perform a task for which it was not suited, and, secondly, the car, when jacked up was not secured adequately, causing it to be vulnerable to movements, bumps and vibrations.
In six of the 27 fatalities, a car was put on ramps and subsequently rolled off onto the victim. In five of these cases the car was not secured by chocks. In the other case, chocks were used but the car slipped off anyway.
In four other cases, the car was elevated, perhaps by jack, but sat on various kinds of structures such as coil springs, wooden blocks, car stands and bricks. The structure failed, resulting in the car falling onto the worker.
Two other cases did not follow the usual pattern. One man was trapped when he was fixing the blade of a slasher and a dog hit the controls in the tractor which was operating it, lowering the assembly onto him. Another was using a pit under his car when the car rolled into it, crushing him.
In the remaining case the only information in the file was that the worker was found with his car collapsed on top of him.
The slasher was not chocked up and was accidentally lowered onto the
gardener/carpenter when a dog bumped the controls in the cabin of the tractor. The tractor
was started up to engage the hydraulics to lift the slasher off the gardener, but the operator
had forgotten the PTO was on and the worker received massive head injuries from the
blades of the slasher. Initially the PTO had been turned off, as was usual practice.
However, the blades of the slasher kept revolving making it difficult to change the blade,
so the PTO was turned on to keep the blades still. An employee of the gardener was also
underneath the slasher when it came down, however he was able to escape being pinned
by the slasher.
The Coroner supported recommendations made by the OHS report and also
added that animals or young children should not be left unattended in the cabins of
vehicles where there is likelihood that their interference with levers or switches could
create a dangerous situation. The OHS inspector stated the contributing factors to the
incident were:
(1) no wooden supports, steel props or other means were used to support the rotary slasher
during the removal of the blades;
(2) the PTO was engaged;
(3) a dog had access to and was inside the tractor cab; ....
An electrician was working on his Range Rover at home when it collapsed onto him. He
was replacing the differential. It appears that after jacking the vehicle up with two small
hydraulic jacks, he then supported it on two coil springs (without the jacks). It is not
known why he did this. It appears that at some stage he probably pulled himself out from
under the rear of the vehicle and in so doing the tow-bar and bumper section collapsed
onto him. The floor of the garage was of dirt, uneven and sloping backwards, and though
not suggested, this may have played a part in the event.
i just pushed ramps up to line up with front wheels then put holes in concrete. Also i have a whole plank of that wood left if you can't find any i can cut some pieces off for you.
