Contacted DW and sent them the failed pump and they replaced it immediately after their checks and sent me new one, installed and it works fine, here are few pics [emoji6]
How difficult is it to install the pump ? Any adaptations needed ?
Question:
Anyone tried to install the IE HPFP in APR one?
I don't know if it's possible or APR has something different inside they pumps rather than others.
Thanks guys.
I did
But u will also need the stock spring instead of using the APR one
Thanks mat
Stock spring with IE HPFP?
The APR spring is much stronger, right?
Correct. The IE internals use the oem spring
Guys is there any DIY for 5th injector driven by BM+ or CM5? I'm trying to figure out the wiring and plumbing.
If I am going for 450 to the wheels can I get away with:
Upgraded lpfp
Upgraded hpfp
Upgraded to fprv
S3 injectors
Prob not with the s3 injectors
