davesee
FIA GT Champion
- Saint Clair Shores, MI
Ok, as my previous thread described, I ran into some problems with my free apr trial... (http://www.golfmkv.com/forums/showthread.php?t=24884)
To make a long story short it left me stranded for a little while not even being able to start my car and with my cel on.
After taking it back to the dealer that installed the trial the first time he read the codes he found:
000665 - Boost Pressure Regulation: Control Range Not Reached
p0299 - 002 - Lower Limit Exceeded - Intermittent
012600 - Intake Manifold Runner Control: Regulation Deviation
p3138 - 008 - Implausible Signal - MIL ON
18258 - Powertrain Data Bus: Missing Message from ECU
p1850 - 000 - - - Intermittent
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
(This error found 4 times)
Now, after clearing these codes he gave me the keys and tried to explain to me that while updating the ecu is being re-written and that various sensors are trying to communicate with an ecu that is virtually non-existant until the re-writing is complete.
I get in my car, start it up and sure enough the cel comes on...
This time he scans and finds:
008196 - Intake Manifold Flap; Bank 1: Stuck Open
p2004 - 008 - Implausible signal
p3138 - 008 - Implausible signal
Then he clears the codes again, takes it for a drive - no cel comes on, comes back turns the car off. Then turns it back on and sure enough the cel is on again. This time the codes are:
004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
p1098 - 001 - Upper Limit Exceeded
(This error 3 times; one for the "Instruments", "CAN Gateway" and "Cent. Elect.
Do you guys think that they've somehow messed up my ecu royally?
Am I just not used to these amounts of codes being thrown seemingly randomly?
I have scheduled an appointment at my local vw dealer to have them check it out. The APR salesman says that the program should not be visible to the vw techs so it shouldn't affect my warranty.
If anyone can lend some insight here, I'd greatly appreciate it!!!
