JETTALINE
Old 07-31-2007, 12:16 AM   #1
dpham00
Modérateur Emeritus
dpham00's Avatar
Drives: 00 Passat 2.0T;07 GTI 2.0T FSI
So, I have compiled a list of common issues and remedies for the 2.0T
So, I’ve compiled a list of common issues and common solutions based on what I’ve seen on the forums. Please research any possible fix before performing it. Personally, I’ve only had a bad pcv, so I’m basing a lot of this based on my understanding of the issue. Please let me know if something needs to be changed or added…I’d like to make this as good a possible.
If your car is stock and you still have warranty, then all the items below should be covered under warranty. If you are not stock, then the failed component may or may not be covered under warranty depending on what caused the failure, though this thread is not a warranty debate thread.
Disclaimer: This is a general guide only. Any problem with the car should be diagnosed by a competent and trained individual. All information provided is for information only and is not designed to replace a service manual or professional help. Use at your own risk.
1. Diverter valve failure
2. PCV failure
3. Broken intake ducting
4. Cam lobe wear
5. High pressure fuel pump failure
6. Air conditioning does not work
7. Tumble flap failure
8. Cold start problems
9. Misfires
10. Low Fuel Pressure Sensor Failure
Background:
The stock diverter valve (dv) is prone to failure, whether chipped or stock. The diaphragm is prone to tearing (the orange shown in the pic of the stock dv (in the middle) below-may be a different color depending on the version of dv you have.)
Symptoms:
-A failing diverter valve will generally lose boost.
-The boost can be checked either via a boost gauge, or the vag-com (mb 115). You will see a huge drop in boost when the dv goes bad.
-Pin-hole DV failures usually allow boost to spike, but will then suddenly vent boost.
Tearing in the DV usually only allows 6-7 PSI. Boost will not spike.
-You may see 000665 - Boost Pressure Regulation: Control Range Not Reached
p0299 - 002 - Lower Limit Exceeded - Intermittent
-Alternatively, you can remove the dv, and inspect the diaphragm for tears. It is held onto the compressor housing by three bolts:
Solution:
-You can replace it with the stock dv, vw #06F 145 710 C. This is the latest dv as of this post, however, many people have also seen failures with the “C” dv. VW is also supposedly coming out with a “G” dv, part # 06F-145-710-G, though it is not officially released as of this post.
-You can upgrade to the Forge DV #fmfsitv. Pics of the Forge DV are shown above.
2. Positive Crankcase Ventilation failure
Background:
The positive crankcase ventilation is supposed to let gases get sucked from the crankcase to the intake manifold when under vacuum. The problem is, when the pcv system fails, and allows positive pressure (boost) to go from the intake manifold back into the crankcase.
The latest PCV is the “G” version. To see which version you have, take a small mirror, and stick it under the pcv valve. The last letter identifies the revision (“E” is shown below). The part # is under the round section:
Symptoms:
-Typically you will see a slight drop in boost pressure. When my pcv failed, I saw a 2 psi drop across the board.
-Some oil will be pushed out through the oil filler cap, and onto the valve cover, and may possibly go towards the coil packs. There may also be some oil on the bottom side of the engine cover, where the oil filler cap is.
-There might be a slight decrease in MPG.
-Rear PCV failure usually results in oil accumulation around the DV, and will produce a little blue oil smoke at WOT applications.
Solution:
-There is the Digitalhippie fix which puts a check valve into the line from the crankcase to the intake manifold. For those who want a spare of the hose where the check valve is installed, the part number is 06F 103 221 F. You can read more about it here: http://www.golfmkv.com/forums/...=8952
-You can also upgrade to the latest PCV “G” valve. There have been very few failures reported with this PCV. Please verify the PCV you have before upgrading.
Part numbers for this upgrade:
PCV valve cover assembly: 06F 129 101 G
PCV valve cover gasket: 06F 103 483 E
PCV valve cover to turbo hose: 06F 103 215 A
PCV tube to turbo metal gasket: 06F 145 757 F
-If you did the DH pcv fix, and you have a rear pcv failure, then you will need to change the tube labeled as "Exhaust turbocharged gas outlet" showin in the pic above. the Part #'s are the last two shown above (06F 103 215 A & 06F 145 757 F)
Background:
Some people have reported that part of the intake ducting that connects to the stock engine (the part in front of the accordion section) breaks off and gets lost, or worst, gets stuck and/or shredded by the fan. Due to its location, the loss in power should be minimal.
Symptom:
-You may notice that part of the ducting is missing.
-You may see shreds of the ducting in and around the fan.
-You may see the coolant temps rising possibly due to a part of the intake ducting getting stuck and not allowing the fan to turn. If the coolant gauge goes into the red, then immediately shut the engine off, and check to see if the fan is operating.
Solution:
-If the fan is damaged, then you may need a new fan.
-An aftermarket intake will replace the ducting section, and is a possibly solution.
-You might be able to tape or epoxy the sections together, so that it will make them harder to come apart. You may also remove the top piece alltogether.
4. Cam lobe wear
Background:
Excessive wear of intake camshaft lobe that drives the high pressure fuel pump. The wear limits maximum pump piston lift, causing fuel rail pressure fluctuations. The intake cam drives the fuel pump:
Please see also #5 below.
Symptom:
-Fuel cut-out when driving, esp. under WOT.
-Fuel cut-out symptoms range from soft pulsations of power to long-pulse bucking while in high-gear high-load situations (high gear at WOT, or up a grade). MIL may flash if cut-out is severe. Car will also go into hard-limp (no boost, 4500RPM limit) if severe enough.
-MIL ON
-P0087 Fuel Rail / System Pressure - Too Low
-P1093 Fuel Trim 2, Bank 1 Malfunction
-P2293 Fuel Pressure Regulator 2 Performance
Solution:
Increase surface hardening of camshaft lobe for the high pressure fuel pump. Improved intake camshafts have Part No. 06F109101B. Refer to TSB# 15 07 04
Background:
The high pressure fuel pump sometimes is not able to supply enough fuel, especially at low to mid range RPMs because it is cam driven. Please note that the high pressure fuel pump is different than the in-tank fuel pump. Please see also #4 above.
Symptom:
-You may see the following DTC
004767 - Low-Pressure Fuel Pressure Regulation: Pressure too High
P129F - 001 - Upper Limit Exceeded - MIL ON
Solution:
-If you are chipped, then try to put the car in stock mode to see if the fuel cuts will stop. If it does, then you might want to wait until a fuel pump solution comes out. APR and Autotech are currently working on solutions.
-If you are stock, then it is possible that you have a bad fuel pump. The dealer should replace this under warranty.
Background:
The air conditioners manuf. By Zelex and Valeo tend to fail. They can be identified by the pulley:
Symptom:
- Air conditioning does not cool, air conditioning compressor may seize.
Solution:
- On the 2.0T engine a new Sanden compressor Part No: 1K0820803 index S must be installed. Refer to ETKA for the latest part # for the other engines. This should be covered under warranty.
[b][i][u][color=red]
dpham00 is offline   Reply With Quote
Old 07-31-2007, 12:22 AM   #2
Lewie94Passat
Audi guy in the MKV F0RUM
Drives: 2006 Audi A3 2.0TM
Send a message via AIM to Lewie94Passat
Background:
The tumble flap motor is prone to failure. This is probably the most common problem I’ve seen when scanning cars with the vag-com. A little background on how the tumble flap works:
Symptoms:
You may see the following DTC’s
-012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded – Intermittent
-012691 - Intake Manifold Runner Control: Open Stop outside of Valid Range
P3193 - 002 - Lower Limit Exceeded - Intermittent
-008196 - Intake Manifold Flap; Bank 1: Stuck Open
P2004 - 008 - Implausible Signal - Intermittent
- 012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 008 - Implausible Signal - MIL ON
Solution: The intake manifold flap motor needs to be replaced.
8. Cold Start Problems
Background/Symptom: Troubles starting car when cold
Solution:
-Some people have reported that it was related to a certain gas, so maybe try a different gas station/company.
-Get the latest software reflash.
-Could also be a bad coil pack.
9. Misfires
Background/Symptom:
-Misfiring either under idle or under boost.
-Scan for DTC’s. See which cylinder is misfiring, and swap coils and or plugs to see if the misfire follows.
-Coil pack misfire (non-fire, lol) symptoms are shorter duration, rather violent, and also result in backfires from unburnt fuel entering the exhaust system. The MIL usually starts flashing. Car may or may not go into limp.
Solution:
-Replace coils and/or plugs
-Could be a bad fuel injector
A special thanks to DirtyDisco. and syntrix for providing some of the info used in this post.
Background/Symptom:
You may get the following DTC’s:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent - MIL ON
P129F - 001 - Upper Limit Exceeded – Intermittent
-The first symptom is typically stalling when first starting the car cold.
-Typically, the problem gets worse, and can lead to fuel cutouts at almost any rpm and/or car stalling/running lean/rich
Solution: Replace low fuel pressure sensor (thurst sensor), vw part #06E906051J
Sometimes, the high pressure fuel pump will be replaced at the same time (#1 in pic below)
-Kris
Last edited by dpham00; 01-29-2008 at 12:47 AM. Reason: mod note: sorry, had to take over thread...not enough room in first post.
Lewie94Passat is offline   Reply With Quote
Old 07-31-2007, 01:27 AM   #3
ketchupfreak
FIA GT Champion
ketchupfreak's Avatar
Drives: 08 G35 Sedan
Awesome! Thanks
SO*CAL GolfMKV Crew #007 bishes!
9.048 @ 79.26
ketchupfreak is offline   Reply With Quote
Old 07-31-2007, 01:38 AM   #4
nice Pants
hi
nice Pants's Avatar
Drives: 07 CW GTI 4dr.6mt.
Send a message via AIM to nice Pants
Originally Posted by Lewie94Passat View Post
Vote for Sticky
x2
nice Pants is offline   Reply With Quote
Old 07-31-2007, 01:50 AM   #5
Andaris
TMV
Andaris's Avatar
Drives: Civic Si
wow are the odds of any of these failing high?
Andaris is offline   Reply With Quote
Old 07-31-2007, 01:54 AM   #6
Stasis
E-Thug
Stasis's Avatar
Drives: 2006 UG DSG GTI
Wow, thanks for this amazing post!
VERY useful to any newer members, and still an awesome reference even for those of us who have had the car for a while and know of the problems.
The odds were higher on the earlier production models, and of course if you are planning on modding your car, such as chipping it.
Originally Posted by Baloocujo31 View Post
I was having a good day until you posted a picture of a cock cumming out of a turbo. Thanks
Stasis is offline   Reply With Quote
Old 07-31-2007, 11:48 AM   #7
dpham00
Modérateur Emeritus
dpham00's Avatar
Vote for Sticky
i'll sticky it in a few days...a lot of people tend to skip over the stickies.
Old 07-31-2007, 12:17 PM   #8
Dave1078
Formula 5000 Champion
Drives: 07 GTI DSG
Nice post. Thanks for putting all that effort into it.
Dave1078 is offline   Reply With Quote
Old 07-31-2007, 12:21 PM   #9
alf
Modwhoreator
alf's Avatar
Drives: \/ \/\/
Send a message via AIM to alf Send a message via Yahoo to alf
great post big d, great damn post.
DBC Performance: Making Shit Happen.
alf is offline   Reply With Quote
Old 07-31-2007, 12:30 PM   #10
Jeffh97
Nanner Puss!
Jeffh97's Avatar
Drives: '06 Candy White GTI
Send a message via AIM to Jeffh97
very nice!
Flickr
Jeffh97 is offline   Reply With Quote
Old 07-31-2007, 12:36 PM   #11
BMdubster
Drives: 07 MKV GTI
Good info ......particularly for MKV noobs like me !
BMdubster is offline   Reply With Quote
Old 07-31-2007, 12:50 PM   #12
LBKEN41
Too close for missiles...
LBKEN41's Avatar
Drives: 2007 UG GTI
Send a message via AIM to LBKEN41
Like I said Dan, you're an encyclopedia of VW knowledge. I'm sure glad you're in my area.
FIGHT ON!
LBKEN41 is offline   Reply With Quote
Old 07-31-2007, 12:53 PM   #13
JPGTI
FIA World Rally Car Champion
JPGTI's Avatar
Drives: 2007 BMP 5-door GTI Manual
Thanks man, this is great.
JPGTI is offline   Reply With Quote
Old 07-31-2007, 01:26 PM   #14
Chongman805
have a BIG one ;-)
Chongman805's Avatar
Drives: CANDY
Send a message via AIM to Chongman805 Send a message via Yahoo to Chongman805
I place my vote for VW man of the year to Mr. Dan. You win buddy. Pass Go collect $200. haha You are awesome man.
Thank you for the endless amounts of knowledge and help you have given us.
Ummmmmmm What?
Go Cry Emo Kid........
www.Dub-Nation.com
http://www.bshftw.com <----only stop you need for all your Dub Part's!
Chongman805 is offline   Reply With Quote
Old 07-31-2007, 03:23 PM   #15
denmkv
Drives: 2007 MKV DSG CW
UR THE MAN !!!! thanks
denmkv is offline   Reply With Quote
Old 07-31-2007, 03:26 PM   #16
sxedub
FIA GT Newbie
sxedub's Avatar
Drives: 07 UG GTi
Send a message via AIM to sxedub
awesome write up
flickr | Bag Riders
sxedub is offline   Reply With Quote
Old 07-31-2007, 05:03 PM   #17
chacho_25
FIA World Rally Car Newbie
chacho_25's Avatar
Drives: Fahrenheit GTI
Awesome Post
Great post man, good info.
chacho_25 is offline   Reply With Quote
Old 07-31-2007, 05:23 PM   #18
shmeeg
monkey with a hand cannon
shmeeg's Avatar
Drives: 2007 GTI
x2 sub
shmeeg is offline   Reply With Quote
Old 07-31-2007, 11:09 PM   #19
MMD
Oval Champion
MMD's Avatar
Drives: Golf 2.0 Gti 6MT
great post man , bravo
MMD is offline   Reply With Quote
Old 07-31-2007, 11:55 PM   #20
graves0927
LegendKiller
graves0927's Avatar
Drives: 07' BM GTI
sticky icky
graves0927 is offline   Reply With Quote
Old 08-15-2007, 11:21 PM   #21
dpham00
Modérateur Emeritus
dpham00's Avatar
Originally Posted by graves0927 View Post
sticky icky
done.
Old 08-16-2007, 08:12 AM   #22
sxedub
FIA GT Newbie
sxedub's Avatar
Drives: 07 UG GTi
awesome! Thank you.
flickr | Bag Riders
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
