Y-Pipe Swap?? worth it?
Plug it. It's worth the 8 bucks for the plug and cap needed :)
Hardware stores and autozone should sell the plug I used. Home Depot has the cap. Make sure you get a hose clamp for the cap on the firewall side. The pic I didn't have one cause it was a test fit.
2zzge
SoCal
GTI
why do we need to cap the firewall hole?
it doesn't go anywhere right? :smoking:
ratboyyy
Cubicle Worker
Carol Stream, IL
x2, yea i didn't do it either, works fine
gtiTom
The Average Asian
North Bethesda, MD
VW MK5 GTI
You know, you could just pull off the pipe, plug it, then put the pipe back on :biggrin:
VW folks will never know, and you won't have to worry about capping lol.
SO, how many horsepowers am I adding here?
Should I wear a helmet?
Will the addition of boost get me laid more?
Will other things happen also as such?
well if ur gonna go that way, then u will see some throttle response improvement, but not much. i would rather go with the real throttle pipe. well thats what i did and it was a big difference.
So, I got lazy and just stuck a big rubber stopper where the silicone connects to the plastic noise pipe. :laugh: I even closed it and it looks stock. Maybe its because I had a few beers before doin it and got lazy. :drinking:
Test drive tomorrow. :burnrubber:
