JETTALINE
Old 04-29-2010, 06:06 PM   #1
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
Talking Whiteline suspension products……..
My buddy (owner of Group5motorsport.com) hooked me up with Whiteline suspension products. Whiteline is hooking me up with a set of sway bars (front and rear), and Anti-lift/caster kit. With a good possibility of getting more products.
I’m excited to see the difference between BSH RSB and Whiteline
UPDATE MAY 22
RESULT:
I finally got my RSB installed. That was very easy to do and I didn’t even have to lower the car off the lift to insert the endlink bolts. Current setup is FSB medium, RSB hard and the WALK kit. This is night and day difference. The car handles extremely good! It is very hard to explain but I am doing my best. The car seriously handles like it is on rails. It just takes all the corners without a problem. The response is also improved. Everything responds much more precisely to the movement of the steering wheel. When I had stock FSB, the front would rub during medium cornering, but not I can take the same corners much faster/harder without rubbing. Everything just feels super tight. One of the best parts of this kit is coming out of corners. I am sure most of you have experienced understeer, too much wheel spin/no traction, and the car acting like it is confused during cornering. 90% of that is gone. Coming out of corners, car has much more grip/traction, much much less understeer, and feels very stable. Driving on the freeway (80-85mph) the car is still very stable, and responds extremely well. I am not sure if it is me or what, but my breaks feel much more sensitive and powerful (stops the car faster).
There is a few drawbacks, little (I mean very little) more noise in the cabin and the front is little stiffer but not bouncy.
So far the car has those as upgrades for handling: all VF engine mounts, ST coilovers, Whiteline 24mm solid FSB, BSH 27mm RSB, Whiteline Anti-lift/caster kit, Flik FTD 17x8 Et.45 with Yokohama S-Drive tires, Hawk HPS brake pads, Goodridge SS brake lines, Motul RBF600 brake fluid, TyrolSport Brake Caliper stiffening kit.
The underbody is dirty because I hit some living creature on a freeway few months back.
The removal of OEM parts
Greasing up the bushings with supplied lube
The FSB's bracket needs to be drilled out and both metal parts will be reused.
Installing the FSB
Installing the WALK kit and bolting everything up
RSB
Originally Posted by tuddy
“air ride functioned as it should have, everything worked good, bagyards road wonderful as they should, but the car had just lost its fun edge.”
Whiteline suspension for MKV (WALK, FSB, RSB, reviews)
rysskii3 is offline   Reply With Quote
Old 04-29-2010, 06:57 PM   #2
Scrooge
Touring Car Newbie
Drives: Nothing right now
i thought the white sway bars were skinner then the stock sway bars ?
The wheels with 10,000 views that never sold.
Scrooge is offline   Reply With Quote
Old 04-29-2010, 07:42 PM   #3
bRett 32
Autocross Newbie
Drives: '08 GTI 4dr/6spd
they are not, nor are you likely to find an aftermarket bar for any street/track application that is smaller than stock - by anyone
bRett 32 is online now   Reply With Quote
Old 04-29-2010, 08:03 PM   #4
brekdown29
J-O-O
brekdown29's Avatar
Drives: grey gli
This RSB works very well...just be prepared to lube the bushings every 5,000 miles or less.
Maxed out tiny turbo
brekdown29 is offline   Reply With Quote
Old 04-29-2010, 10:25 PM   #5
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
thats not a problem
Old 04-30-2010, 07:27 PM   #6
kidthunder
VAN$$$DAMAGE
kidthunder's Avatar
Drives: 07 BMP GTI
im thinking of getting the white line anti lift caster kit so a good reveiw would be nice
kidthunder is offline   Reply With Quote
Old 04-30-2010, 07:30 PM   #7
supaflip
WWAATTAAHH!!!
supaflip's Avatar
Drives: 2007 MKV (BM) Pkg 2
is the rsb hollow? and do u know what size of rsb u're getting?
sub'd
supaflip is offline   Reply With Quote
Old 04-30-2010, 08:39 PM   #8
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
sub'd
it should be 24mm 3way adj
Old 05-01-2010, 01:29 AM   #9
bRett 32
Autocross Newbie
is the rsb hollow?
sub'd
The Whiteline bars are solid.
Old 05-01-2010, 01:33 AM   #10
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
didnt know that
Old 05-01-2010, 11:29 PM   #11
Paul_OH
FIA World Rally Car Champion
Paul_OH's Avatar
Drives: GT TSI
Send a message via Skype™ to Paul_OH
I just replaced the Whiteline bushes today with the H&R teflon impregnated bushes after having to relube every 2-3 months. Just a heads up to save you some extra work down the track.
Also be careful with sway bar lateral movement as the Whiteline clamps tend to move and you can end up with 1.5-2" lateral movement as the clamps are not permanently mounted to the RSB.
5 of us bought these down in Perth and all are having the same issues - the benefit and feel does outweigh the cons but if you do the bushes from the start it may prevent some cursing at a later stage
Paul
http://www.pbase.com/paul_oh
Paul_OH is online now   Reply With Quote
Old 05-02-2010, 12:12 AM   #12
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
Paul
where did u get them? i just looked around and they are not being sold separately
Old 05-02-2010, 12:16 AM   #13
bRett 32
Autocross Newbie
H&R sells them as replacement parts for something like $15 each - you can PM me if you'd like some
Old 05-02-2010, 12:19 AM   #14
Paul_OH
Paul_OH's Avatar
Drives: GT TSI
Good question but I don't know the answer sorry, one of the Oz guys bought a heap ex USA and distributed them locally.
edit: see post above mine^^
Old 05-02-2010, 08:12 AM   #15
ViRtUaLheretic
Word to your mother
ViRtUaLheretic's Avatar
Drives: 2009 VW GTI BMP
Ill be following this thread to see what you think of the WALK
::APR stock/91/93/100::BSH Race Intake::BSH VTA Race Can::BSH Motor Mounts::BSH Pendulum Mount::
::BSH TB Pipe::Devils Own DVC-30 w/m kit::Neuspeed Insert::Neuspeed SS Brake Lines::
::DEFI gauge::17x8 Flik FTDs::BFG 235x45x17 rubber::
paitentially waiting for TSI mods.....
Read this for TSI INFO/FAQ
ViRtUaLheretic is offline   Reply With Quote
Old 05-04-2010, 03:19 AM   #16
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
the parts will be here on wed...
Old 05-06-2010, 06:11 PM   #17
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
updated
Old 05-06-2010, 06:27 PM   #18
GTIWV
WV VW
GTIWV's Avatar
Drives: 08 CW GTI 6MT
Send a message via AIM to GTIWV
Definately want to see what you say about the anti-lift kit. I have been interested in that since it came out
'08 CW GTI
APR K04
GTIWV is offline   Reply With Quote
Old 05-06-2010, 07:52 PM   #19
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
it will be hard to tell which part did what since everything is getting done at the same time, but i will do my best. also, this setup is replacing the BSH rsb
Old 05-06-2010, 08:16 PM   #20
GTIWV
WV VW
GTIWV's Avatar
I dont blame ya at all
'08 CW GTI
APR K04
Old 05-06-2010, 08:21 PM   #21
rysskii3
VeeDub KING
rysskii3's Avatar
Drives: MKV GTI
its a great bar, but this deal is sweeter, so the bsh bar has to go
Old 05-06-2010, 08:27 PM   #22
bRett 32
Autocross Newbie
Rear bars aside you should certainly be able to feel (and see) what the WALK does for your car. The steering feel and front traction will be noticeably improved.
As for going from a large rear bar to 24mm front and rear, you'll likely lose some lift-throttle rotation but pick up some grip and balance in steady-state cornering. Both bars are adjustable so you'll be able to dial in the balance to your liking, if you're a big autocrosser you may miss the rotation of the rear end, but if your car spends more time on the track it will almost certainly be quicker and more predictable.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
