JerseyDrew77
- Virginia & NC
- 2016 TR GTI S 6MT
I agree with the BFI mounts. It's too bad the SuperPro mounts aren't made anymore.
So glad I got my Superpro mounts when I did.
I actually have a set that I'm waiting to install when the OEM mounts need replaced. Paid way too much for them on Ebay from the UK when they had quit making them but I found a set. What is your opinion on added vibration versus OEM? I'm in my car 8-9 hours a day making deliveries and am concerned about the vibration. I know that I would get used to a little added vibration but am worried that it will be too much. Can you possibly compare them to the BFI stage 1 mounts with regards to vibration?
The Superpro mounts add very little in the way of vibration/harshness... You do get a bit more noise from both the engine and transmission. Think of the mounts as a stethoscope to get a good idea what I mean.I actually have a set that I'm waiting to install when the OEM mounts need replaced. Paid way too much for them on Ebay from the UK when they had quit making them but I found a set. What is your opinion on added vibration versus OEM? I'm in my car 8-9 hours a day making deliveries and am concerned about the vibration. I know that I would get used to a little added vibration but am worried that it will be too much. Can you possibly compare them to the BFI stage 1 mounts with regards to vibration?
There is absolutely no added vibration whatsoever! It feels just like a car that is stock with OEM mounts.
I have the 034 density mounts paired with a APR pendulum mount.
Are vibes there?
Yes, but, I don't have to worry about polyurethane.
Polyurethane is great if you only plan on keeping the setup for a couple years. If you're going super long term or don't mind replacing the inserts say, every five years if you drive your car in the winter, poly with be stiffer.
R Line has a full poly mount along with a replacement billet dogbone arm. Buddy has all three R Line mounts on his car and after break in vibration and harshens is not too bad considering they're solid, high durometer polyurethane. Downside is you hear everything from the engine and transmission. This is because the mounts are effectively stethoscopes mounted to the frame of the car.Is there a full poly dogbone mount? I've only seen inserts, or replacements just for the arm itself.
The powerflex hybrid puck is poly, replaces the entire lower puck and has an insert into the upper puck as well. I'm running it with stock motor / trans mounts right now but I'll likely be replacing those soon since the powerflex puck will likely cause them to wear quicker.Is there a full poly dogbone mount? I've only seen inserts, or replacements just for the arm itself.
The mounts really should be replaced as a full set. Engine, transmission, and dogbone mount. You most definitely are putting additional strain on not only the other mounts, but also the other parts of the drivetrain if you don't replace all three as a set.The powerflex hybrid puck is poly, replaces the entire lower puck and has an insert into the upper puck as well. I'm running it with stock motor / trans mounts right now but I'll likely be replacing those soon since the powerflex puck will likely cause them to wear quicker.
Bingo, hence why I said I'll be replacing the rest of the mounts in short order.The mounts really should be replaced as a full set. Engine, transmission, and dogbone mount. You most definitely are putting additional strain on not only the other mounts, but also the other parts of the drivetrain if you don't replace all three as a set.
