WHAT HE SAID .... never saw a kit with original intake.. we use the BMC DIA AIRBOX.
psycho, you can swap the impeller, the gears by yourself. its nothing shrunked on or stuff like that... you need to loose some bolts and thats it.
for going from stage 2-3 you either need an different housing (not that expensive) or you use the original housing and go with some silicone hoses. will look like this!
you can rotate the housing 360°. you just need to loose the bolts, turn it in the position you want and tight it again! like a turbo housing!
Telaio, we map your car in the time we install the kit?
