I have spoken to Brian from Ohlins several times. He has taken very good care of me and have even offered me a full return. Very solid company but they have no intention of modifying this suspension. The problem with my platform is very low production numbers and thus very low demand for the product. Ohlins has since changed their marketing to say their suspension will perform better than stock but will not offer any ability to lower the car.
It should be noted this is my fourth set of Ohlins. I've run them on all my previous platforms. They are really top of the food chain before you jump to a competition level shock priced north $5000. I apologize for taking this thread slightly off topic but the truth of the matter is to get maximum suspension travel on a MQB most of us will require a camber plate with a deep shock mount point that in turn requires shock tower modification.
At this point the only camber plate that appears to fit the bill is the Ground Control and even it has some limitations that may require some home grown work arounds to address. I believe Cliff's photo is about the cleanest example of what is required. Having the horseshoe plate under the top of the shock tower gave up about a 1/4" of suspension travel but also allowed the plates to provide maximum negative camber. This approach would still give you more travel than Super Pro, 034, Vorshlag or OEM.
But even with that approach, if you are running to top adjusting shock (like most of them are including MCS) you will still need to cut the top off. The picture I posted above of the modified tower with JRI shocks is a good example.
