However he said according to VW that whenever the pads are changed the rotors need to be changed to to be kept covered under warranty.
Well he's kind-of right. VW won't warrant non-OEM parts but how often do disc rotors/brake pads poop themselves. If you fit quality aftermarket gear, warranty for those items is then transferred to the manufacturer of those items. Disc pads & rotors aren't warranted for wear, so all you are concerned about is manufacturer defects.
The only reason the rotors need changing is if machining them brings them below the minimum thickness. IIRC new is 25mm & minimum is 22mm, so there isn't much to play with there.
I'd go aftermarket every time.
He said that the stock pads and rotors are softer than other standard cars for comfort, noise, and extra braking power. And because the rotors are softer they don't last as long...
That's more or less right
Anyone else gotta do this? I'm thinking of either going aftermarket (any suggestions?) or not changing the rotors (are the rotors that soft they last only 45000k?)
If you put new pads onto old rotors they will:
a) Take forever to bed in & get full pad to disc contact
b) Will probably shudder, vibrate & feel like crap.
c) The reduced metal mass of the old rotors (they act as a heatsink) will mean that your brakes will tend to overheat quicker & nor be as effective if you tend to use the brakes heavily.
d) Wear the pads out quicker
So not a good idea.
I'm not quite sure why you want to go to the R32 upgrade path. Why not look at some quality rotors - at a minimum something like DBA 4000 slotted or even 2 piece rotors (usually lighter) with a Ferodo 2000 or 2500 compound pad.
try compfriction.com.au or racebrakes.com.au
there also a
brake guy over at VWwatercooled that does some reasonable stuff (Remsa, QFM, EBC, DBA, etc).
Keep in mind that some of the pads don't have the wear sensor built in.
/searches.... bugger, can't find the link but I was looking at a UK(?) site the other day & they must have had 10 different brands of rotors for Golfs.
Found it:
DC Performance
Also, i have bought from
JKM Performance
