mdashali
So here is my story:
In preparation for my drive to Lake Tahoe (~500 mile to and fro) during the July 4th weekend I seafoamed the intake, changed oil and filter (@ 15K - i usually do 5k OCI), rotated the tires - all one day before my trip. During the trip I noticed that my GTI takes almost a second to launch from 1st gear (I have a DSG) and then my gas mileage for the whole trip was 24 mpg which is lower than my typical city average (26-27mpg). On top of this, I am getting vibration in the steering wheel when I go past 65-70mph. None of these problems existed before my prep for the long drive.
So here are my questions:
(1) Could Seafoam done any damage? I have used it previously on NA motors so I don't know Turbo DI motors are sensitive.
(2) Can I reset the ECM by disconnecting the battery without any side effects if that is going to help with acceleration problem? I know it sounds lame but I just want to make sure.
(3) Steering wheel rattle could be due to alignment issues. Is alignment covered under warranty and all dealers are generally equipped to do it?
Solution:
Used VagCom to detect that cylinders 3 & 4 misfired. Bought a new set of OEM Laser Platinum spark plugs ($16 each) and replaced it over the weekend. The car drives now normally. The old spark plugs didn't seem to have been fouled that much. It looks like our GTI is very sensitive to the spark strength. I have saved the spark plugs for next time when I seafoam in another 15K.
I also used VagCom cable to do some tweaks - 5 blink turn signal, fog light cornering, remote up/down windows, gauge sweeping aka staging, coming home, auto head light switch off on key removal etc.
I still have to do alignment and wheel balancing to fix the rocking steering wheel.
Solution:
