vbmkv
- virginia beach
nice! fixed the coolant fuck up, and was able to twist the line back to normal. she started right up! thanks for all the help!
well fuck me, when i went to disconect the line , some how i broke a nipple off a coolant hose,
http://s1295.photobucket.com/user/taylor_robertson1/media/IMG_0449_zps1feec308.jpg.htmlhttp://s1295.photobucket.com/user/taylor_robertson1/media/IMG_0451_zpse3a1a202.jpg.html
anyone know where i could get a replacement?
I'm getting a '07 2.0 FSI, no turbo... is this something that I should check?
Yes, check it before buying it.
Very detailed DIY!
For me, I just use a 13mm wrench and take off the pressure valve then i use a 17 wrench and lossen the bottom nut, take off the sensor clip and use a T30 and unboltthe three torx screw and pull of the pump
I have been putting this off and putting this off because I was worried something would get screwed up. Well I should have listened to my gut.
The disassemble went great - it was in fact really easy thanks to this write up and sure enough my cam follower was due to be changed (no black coating left). I put it back together spun the silver compression nut up and got it threaded all nice and then put what I felt was the same amount of force back on as was on there to begin with.
Hopped in ... waited cranked and it started up hooray I thought all that worry for nothing... not so fast. On closer inspection gas was dripping out around the the treads above the silver nut. I determined it wasnt coming from above and that it was squeezing up from the compression joint. No worries I thought maybe I didnt get it tight enough. well it was on there tight, I cracked a bit more and it seemed to make matter worse. So then I decided to take it all apart again, and check to make sure all the surfaces were clean. I cleaned them with cloth removing a fine film I removed the brass thing from pump (its not a PITA to get back in by the way). cleaning seemed to help but instead of dripping it wells up on the threads and sits there. Without a crows foot for my torque wrench I cant check the torque (ive ordered some) I also ordered the brass piece ($6 +$7 for shipping from ECS) the stealership wanted $14 plus tax. Mind you it will take 5 days for it to arrive. My only hope is that is not the stainless steal line as that looks like a real pain to get out from under the intake. Its been a stressful afternoon. Something that was supposed to be done in 1 hr dragged on for 5 Anyone else had this problem? Any suggestions ? Thanks.
