judunty84
- Hagerstown, MD
- 07 3 Door GTI
*EDIT* rough acceleration, no cel, STILL can't tell what it is!
I have a 2007 FSI with an APR stage 1 flash with 69,xxx miles on the clock. Everything else motor wise is stock. So for the past month or so under light load in low rpm i have gotten a few little hitches during acceleration, but nothing really concerning.
Fast forward to today and it has gotten worse. When the motor is under load in mid rpm's there is quite a bit of stuttering. It is strange because my initial reaction was that the clutch was going bad because I can hear the motor boost and the boost gauge seems normal. Then I starting straying away from the clutch idea because the rpm's don't seem to jump as if the clutch was slipping. The strange thing is as it builds boost and hits higher rpm's it clears up and runs fine. It seems like from 2000 rpm to say 4500 or so is the worst.
It is not showing a CEL and unfortunately i don't have access to VAGCOM. Here is a list of ideas but I don't want to start spending $ on parts until i have a good direction...
-clutch going bad
-fueling issue (cam follower was changed for the second time at 60k
-plugs (were changed 30k ago at the 40k tune up)
-coils (were changed by dealer under TSB)
-something else and i have no idea!
it is just weird to me if it is an engine related issue and there is no CEL on. That is why i initially thought clutch.
Any advice?
Thanks!
-clutch going bad
Any advice?
Thanks!
