Perpetuus
Data Encryption
- In my garage
I spent the morning swapping out my seized rear rotors and put on new rear pads. I rented the rear caliper piston compressor tool, thinking it would be an easy job...not so..
With the tool, I was able to retract the piston only 1/2 a turn clockwise. After that, I had to put the vise grip onto the handle to attempt to turn it more. No luck though...the piston won't turn anymore. I need the piston to retract back about 3/8" more to fit the new pads. The old pads were worn and seized before.
This is on the right hand side of the car, which is the caliper with the parking brake. Is there a trick to get them to retract more? Are they seized? The area around the dust boot and directly underneath the boot looks ok.
