Old 02-10-2008, 07:37 PM   #1
Meat
rack rack 'em
Meat's Avatar
Drives: 2007 MKV GTI
Send a message via AIM to Meat
Meat's Brake DIY (w/ thanks to DanGSR)
DISCLAIMER: Neither I nor any other members who have lent their advice or expertise to the writing of this DIY take any responsibility for any damage to personal property or injury to yourself...
Tools needed:
- 2 ton Jack and jack stands (preferably 4)
- 17mm deep socket or 17mm socket with extension (for lug nuts)
- torque wrench (optional-to tighten lugs to spec)
- 13 mm socket (or wrench)
- 21 mm socket
- 15 mm wrench
- M14 triple square bit. I recommend these: http://www.amazon.com/Pc-XZN-Bit-Dri...9184466&sr=8-2
- T30 bit or driver
- Socket wrench with a breaker-bar
- Piston reset tool, available to rent from AutoZone or buy it here: http://www.metalnerd.com/cat08.htm
- Anti-squeal paste
- Brake and caliper grease
- 7 mm allen key
- piers
Rear Brake Pads and Rotors
****If you are only going to swap pads, skip steps 4-6****
1. Loosen all lug nuts. Jack up car and remove wheels, always use jack stands, NEVER work on a car supported by only a jack
2. Remove the two bolts from back of the caliper using 13 mm and 15 mm wrenches
3. Remove the caliper, rest it on a jack or zip-tie it up so that the lines don’t stretch
4. Remove the two bolts holding on the carrier using an M14 twelve point bit.
5. Remove the carrier and remove the old pads from it. Set it aside.
6. Using a T30 bit, remove the screw holding on the rotor and remove the rotor
7. Sparingly apply some anti-squeal paste to the back of the pads, be sure to not let ANY of it touch the surface of the rotors or pads. Spread it with a plastic shopping bag or other clean-disposable spreader
8. Place the pads in the slots in the carrier
9. Replace the rotor and bolt the carrier back on, place some grease on the carrier bolts
10. Using the piston resetting tool, compress the piston as far as possible
11. Slide the caliper onto the carrier and bolt the caliper back on
12. Check all of the bolts to make sure that they are tight. Make sure that your lines are not leaking at the fittings, and make sure that the rotors are clean. You can spray them with Brake Cleaner to make sure, but do not let the brake cleaner touch the brake pads
13. Repeat for the other side.
Front Brake Pads and Rotors
1. Remove the metal clip holding the front caliper to the carrier using a large flathead screwdriver or pliers
2. Remove the black plastic caps covering the bolt that hold the caliper on. Using a 7 mm allen wrench, remove both of the bolts.
3. Remove and secure the caliper so that the lines aren’t stretched
4. Using a 21 mm socket, remove the bolts that hold on the carrier
5. Then remove the carrier and the screw that holds the rotor on, remove the old pad from the carrier
6. Replace the rotor and the screw that holds it on, then lightly grease the carrier bolts and bolt the carrier back on
7. Pull the old inboard pad off of the caliper
8. Sparingly apply some anti-squeal paste to the back of the outboard pad, be sure to not let ANY of it touch the surface of the rotors or pads, place the pad in the carrier
9. Using a pair of pliers, squeeze the metal tabs on the back of the inboard pad to get them to fit inside the caliper hole, be sure to not contaminate the surface of the pad
10. Using either your hands, piston resetting tool, or a C-clamp, compress the piston all of the way
11. Slide the caliper onto the carrier and over the pad already on the caliper
12. Lightly grease the bolts that you removed from the caliper and bolt the caliper back on using the 7 mm hex key and replace the black caps and the clip on the outside of the caliper using a pair of pliers.
13. Repeat for the other side. NOTE: if your pads come with wear-sensors, you will have to unplug the cable from the old pad and plug it into the cable on the new pad. The pad with the wear sensor is the inboard pad on the front left side.
Finishing up
1. Place the wheels back on and tighten the lugs hand tight
2. Lower the car and torque the lugs to 88.5 ft/lbs 120 Nm)
3. Start the car and pump the brakes until they are firm. Your brakes may feel funny for the first 200 feet so make sure you aren’t in danger of hitting anything or rolling into anything.
4. Follow the bedding procedure outlined in the paperwork that came with your brakes. This usually involves making a few hard stops from various speeds.
Changine Brake Lines
You can change your brake lines before changing the pads/rotors or afterwards, it doesn't really matter. Just be sure to properly bleed the brakes once you are finished.
Here is a good write-up on line changing from Neuspeed. Thanks to xSabertoothX for the link: http://www.neuspeed.com/installation...&ltype=ns_euro
Torque Specs
Guide pins on the front caliper: 30 Nm
Front carrier bolts (21mm): 190 Nm
Hex bolts on the rear brake caliper: 35 Nm
12-point bolts that hold rear carrier: 90 Nm + 90 degrees
Rotor set screws: 4 Nm
Brake lines: 14 Nm
YouTube
Flickr
ERAU
Meat is offline   Reply With Quote
Old 02-11-2008, 01:11 AM   #2
ESPNVW
WRC driver wannabe
ESPNVW's Avatar
Drives: MKV GTI
Nice write-up!
ESPNVW is offline   Reply With Quote
Old 02-11-2008, 01:55 AM   #3
MACH GTI
Rally Car Champion
MACH GTI's Avatar
Drives: Black 08 GTI
why did u take out the rotors also? did u change rotors too?
MACH GTI is offline   Reply With Quote
Old 02-11-2008, 01:57 AM   #4
maxgtiturbo
Chapter 11 Dubs
maxgtiturbo's Avatar
Drives: Volkswagen
do i smell a sticky??
Flickr photobucket (Click me!)
maxgtiturbo is offline   Reply With Quote
Old 02-11-2008, 02:16 AM   #5
crabpot
Awesomesauce
crabpot's Avatar
Drives: 07 GTI: BMP
Send a message via AIM to crabpot
Good info, thanks Meat.
Sticky?
BPCDubs » We use a bidet, that's how euro we are.
crabpot is offline   Reply With Quote
Old 02-11-2008, 10:06 AM   #6
CiDirkona
Formula 5000 Driver
CiDirkona's Avatar
Drives: MKV GTI, B5 1.8t
Send a message via AIM to CiDirkona
This DIY was posted about 15 minutes after I checked for one and had to figure out all this stuff on my own. Ha!
Please sticky this!
Installed:SouthBendS3Clutch,KSportCoilovers,27mmBS HRSB,ATP3"DP,(1/2)*PFlow,GIAC+100octane,SnowPerfWaterMeth,EurojetF MIC,BSHDV,IridiumPlugs,NewSouthGuagePod,IndigoBoos tGauge,Xenonmatch9006,WasteGateRig-o-Matic,RS4Reps18",FalkenZiex512,PaintStripeyandRoof
Ordered/ToBeInstalled:LowersPainted
CiDirkona is offline   Reply With Quote
Old 02-11-2008, 10:20 AM   #7
Meat
rack rack 'em
Meat's Avatar
While doing this DIY, I was taking off my race brakes. I am going to run Carbotech XP10's which can be a bit harsh on rotors so ordered another set of OEM rotors to be used specifically for those pads. I installed all of that the day before and then took pictures of the process of swapping it back. In the DIY I was removing those pads and rotors and swapping back to my original rotors and some Hawk HPS pads.
YouTube
Flickr
ERAU
Old 02-11-2008, 10:22 AM   #8
Meat
rack rack 'em
Meat's Avatar
Please sticky this!
Damn, sorry! There was one by digitalhippie, but he took it down. I figured it would be helpful to put one up.
YouTube
Flickr
ERAU
Old 02-11-2008, 11:10 AM   #9
MACH GTI
Rally Car Champion
MACH GTI's Avatar
ohss k cool hows the Hawks HPS on the stock rotor? does the stopping power and distance stronger and shorter as it claims to be?
Old 02-11-2008, 11:23 AM   #10
Meat
rack rack 'em
Meat's Avatar
They aren't too hard on the stock rotors. They will hold up very well. There is a very noticable difference between the stopping power of the Hawks vs. the OEM pads.
YouTube
Flickr
ERAU
Old 02-11-2008, 12:06 PM   #11
julito04
I plead the fif.
julito04's Avatar
Drives: 06 UG GTI
Send a message via AIM to julito04 Send a message via Yahoo to julito04
very nice write up. thanx for pullin through in the clutch. ill be using this DIY in about 3 weeks, yippy!
About carchrisM5:
Originally Posted by JAK-RBT View Post
bahaha
caramel mocha latte kool-aid s6 LED motha truckin shark divin man... ohhh yeaah
julito04 is offline   Reply With Quote
Old 02-11-2008, 12:24 PM   #12
NoRegrets78
It's possible...
NoRegrets78's Avatar
Drives: Contemplating a return...
Send a message via AIM to NoRegrets78
Excellent write up, thanks much!
NoRegrets78 is offline   Reply With Quote
Old 02-11-2008, 12:27 PM   #13
Wild Hare
.:: AMSOIL Dealer ::.
Wild Hare's Avatar
Drives: NEXT CAR IS A GOLF R!
Good write up.
I do like the McKay Spray a little better though. Aaron at Neuspeed turned me on to it.
Retired U.S. AIR FORCE Combat Aircrew, KC-135A/Q/R Boom Operator
Wild Hare is offline   Reply With Quote
Old 02-11-2008, 01:36 PM   #14
CiDirkona
Formula 5000 Driver
CiDirkona's Avatar
BTW, Step 2 rear brakes on my car was a 13mm on the back and a 15mm on the slider-piston thing...
Old 02-11-2008, 01:51 PM   #15
Meat
rack rack 'em
Meat's Avatar
Really? I tried a 15 and it didn't fit, at least I don't think it did. I used a 16mm but I'll check that size again.
EDIT: it's 15mm
YouTube
Flickr
ERAU
Old 04-25-2008, 04:01 PM   #16
julito04
I plead the fif.
julito04's Avatar
Drives: 06 UG GTI
bumpoooo. using this today in about 3 hours. woohoo!!
About carchrisM5:
bahaha
Old 04-25-2008, 05:59 PM   #17
GTI2007
Moderator
GTI2007's Avatar
Drives: '05 UG Golf 5 Plus
Pretty nice write-up
GTI2007 is offline   Reply With Quote
Old 04-27-2008, 05:58 PM   #18
HaZZvDub
HaZZvDub's Avatar
Drives: CW STG2 MKV
Awesome. Helped alot !
HaZZvDub is offline   Reply With Quote
Old 04-27-2008, 06:13 PM   #19
Meat
rack rack 'em
Meat's Avatar
Glad to hear it has been of help.
YouTube
Flickr
ERAU
Old 04-27-2008, 10:00 PM   #20
bonton
Oval Newbie
bonton's Avatar
Drives: GTI 12/05
Please Sticky this.
Let a coonass have a GTI
bonton is offline   Reply With Quote
Old 04-28-2008, 03:21 AM   #21
Zack @ Neud Clothing
NeudClothing.com CHECK IT
Zack @ Neud Clothing's Avatar
Drives: 2007 e92 335i Space Grey
Oh boy. Those will be deleted soon.
>>>>> CLICK IMAGE TO VISIT NEUDCLOTHING.COM <<<<<
For some more info on our company, please check out our thread!
http://www.golfmkv.com/forums/showthread.php?t=104552
Zack @ Neud Clothing is offline   Reply With Quote
Old 04-28-2008, 08:02 AM   #22
generic83
lol wheel spin
generic83's Avatar
Drives: 07 Tornado Red GTI M6
Ahh this is fantastic, book marked. Im gonna need this when I do pads, lines and fluid.
APR Stage 2/APR DP/Snow Meth Injection/Neuspeed SRI/BSH DV/K-Sports/ASA AR2s
generic83 is offline   Reply With Quote
Similar Threads
Wilwood Brake Kit? mel22b Wheels / Tires / Suspension / Brakes 17 10-26-2009 01:26 PM
*MKV GTI BIG BRAKE KIT! DTMRyan SPONSORS Classifieds Area 11 01-21-2008 04:56 PM
DIY for brake pad install odascoo Wheels / Tires / Suspension / Brakes 11 01-08-2008 01:43 AM
Brake Light Recall davesee General VW Cars Talk (non-MKV GTI/Rabbit related) 12 02-26-2007 07:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
