Hey guys, not to much info on this topic, ive done my searching and understood that Podi have still not come up with a solution for an oil temp gauge, new south has 2 solutions, the drain plug (which is not very accurate because it is post cooling) and the banjo bolt (more accurate)..
However i dont know which part i would need from new south to install my aem oil temp gauge if i wanted to use the banjo, and i only found a DIY for the oil pressure, are they the same location, could i just install the oil temp in place of the oil pressure fitting? It is 1/8..
http://www.aemelectronics.com/1-8-ptf-water-coolant-oil-temperature-sensor-kit-1237 Would this sender fit with the banjo mod?
Thanks
Thanks
